Tip & How-To about Pool & Spa
INTEX POOL CLEANING
YOU CAN USE A 30 GALLON CLEAN PLASTIC DRUM TO VACUUM OUT YOUR POOL BY GOING IN ONE SIDE WITH YOUR OUTLET HOSE CONNECTION WITH A 6 ' PIPE INSIDE THE DRUM, AND BY USING A PIPE 4 INCHES OFF THE BOTTOM ON THE DISCHARGE SIDE GOING INTO THE PUMP. COVER THE BOTTOM OF THE DISCHARGE (THE LONG PIPE) WITH A PIECE OF PANTYHHOSE CLAMPED ON THE END AND THE TRASH FROM THE POOL WILL STAY IN THE DRUM INSTEAD OF GOING INTO THE FILTER. AFTER VACCUMING OUT DISCONNECT THE DRUM, AND REHOOK YOUR HOSES AS NORMAL TO THE PUMP. CLEAN THE DEBRIS FROM THE DRUM AND YOU'LL BE READY FOR THE NEXT TIME. JUST FILL THE DRUM BEFORE YOU START WITH POOL WATER,IF YOU DO THIS YOU WON'T LOSE ANY WATER. OF COURSE YOU HAVE TO PURCHASE THE CONNECTIONS TO ADAPT TO YOUR HOSES. BLEED THE AIR OT YOUR PUMP AND YOU'LL BE AMAZED AT HOW MANY FILTERS YOU SAVE FROM THE TRASH FROM VACUUMING STRAIGHT INTO THE FILTER.
Pool & Spa Logo
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Is there a filter in Kenmore Dishwashers that need rinsing or changing? Our dishwasher seems to be backing up, leaving "silt" on the dishes. I empty the screen on the door, but residue has built up elsewhere.
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Apr 22, 2011 | Dishwashers
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
cycles take too longon my GE Adora front load washer; the speed cycle is normally 30 minutes but takes 1.5 hours
It is probably the fill valve filter which is blocked or the drain outlet is obstructed.
You can clean the fill valve filter by turning the water off and disconnecting the hose ot hoses
There is a plastic filter just inside the valve which needs to be kept clean
If you have a slow discharge from the drain pump that also will cause the machine to take a long time on a cycle
Take the discharge hose out of the waste pipe clean the end and get someone with strong lungs to blow down it you should be able to hear air bubbles inside the machine if not then you may have a sock stuck in the pipe from the drum to the pump
Jun 08, 2009 | GE WSXH208A Front Load Washer
hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
288 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
