Tip & How-To about Computers & Internet
How to apply video effects in video editor
Introduction
  • Step 1: Add the desired effect to the Timeline
  • Step 2: Define the effect startup moment
  • Step 3: Define the effect duration
  • Step 4: Adjust the effect properties
Video Editor has a lot of features to make your video stuff even far more memorable and impressive. Adding different effects to your video is one of those catchy things that approximates the resulting video to the interesting and amazing work. If you are a new user you’d better learn how to import your video and place it to the Timeline first and then adhere to the steps of this guide to see you will succeed in applying effects for sure.
Click the Video Effects pane and choose the effect you like best in the right area then drag and drop it to the Video effects row of the Timeline:
Click the effect block and move it along the row holding the mouse button, if the suitable moment for the effect to start is caught release the mouse button:
Bring the mouse cursor to the effect block right border until it looks like . Without releasing the left mouse button stretch or narrow the block, if the suitable moment for the effect cancellation is caught release the mouse button:
Note: you can also define the effect duration by clicking the Duration button which appears on the panel placed a bit above at the moment you click the effect block.
Double click the effect block to load its properties window and adjust them the way you like then click OK:
Besides this , you can use other tools such as video converter to help you in dealing with the
related information for you.
If you have a blackberry device, you can also use a dvd to blackberry converter to help you
solve the problem easily.
I do hope you can like it , I have tested them already, they are really very easy to use , easy
to download and install. Just have a try, I won’t let you down! Good luck to you!
Computers & Internet Logo
how to use adobe premiere pro 2
Adobe premiere pro is software for video producers that takes you from the start to completion of your video project. You will run into less conflict working with other video formats due to the "Native Editing Support" from "SD" to "HD" that is provided in this software. A convenience is that every workspace has a separate panel and when using multiple panels they can be docked where you want.
Please follow the below step.
Step 1: Open the premiere software and choose which project you will be working with, either a previous, recent or new project. No need to change the default settings at this time.
Step 2: Go to the "Capture Format" menu and choose the type of format you want to capture, for example from the web or a dvd. (http://www.ehow.com/internet/)
Step 3: In the dialog box at the bottom give your project a name and determine the folder you are going to use to save your project. Before you click OK, select the "Scratch Disks" tab to create your own folder structure, this will make it easy when it comes time for you to move the media and archive. Now choose the folders you want to store the captured media you identified in step 2 and when you are ready, click "OK."
Step 4: Work with your sequences in the "Workspace Layout." This area is divided into sections, the top left and middle contain the project panel, source monitor and effect controls. The top right of the workspace contain the audio mixer and program monitor. The left lower section contains the media browser, info panel, effect panel, sequence and history panel. The bottom right panel contains the tracks, time-line, clips and audio meter.
Step 5: Edit your sequences using the "Timline Panel." Each sequence you add will appear as a tab within the "Timeline Panel." You are not limited to the amount of sequences you create or number of timelines you open.
Step 6: Create your video and audio using the "Tracks" feature. Each clip you add to the sequence needs to have a track identified. This is where you are adding sound to your sequences within your "Timeline Panels."
Step 7: Trim your clips using the "Source Monitor." Here you can add or remove a sequence by double clicking on the clip in the "Project Panel." You can then play back the clips in the sequence you assembled to view your project.
Step 8: Access the "Project Panel" and "Media Browser" for links to the different aspects of your video project when you need to add, change or remove sequences. When you are ready, go to the "Effects Panel" and begin setting the desired effects to the sequences you created.
Step 9: Open your "Tools Panel," which provide shortcuts on the keyboard for several of the functions mentioned in earlier steps. This is the beginning steps in using adobe premiere pro, to continue to the end of your video/media creating follow the prompts.
Thanking you
davevipul197
Jun 02, 2011 | Adobe Computers & Internet
how to upload pictures to video
Turn your Artwork or Photos into a "video slideshow" using Movie Maker 2.0 If you have a series of images on your computer, say, from a digital camera, you can turn these pictures into a video. Movie Maker 2 has a storyboard mode that makes it really easy to turn your photos into a "video slideshow." Simply import your photographs and drop them onto the storyboard in the order you prefer. After you've placed your pictures, you can do a bunch of great things to your photos to spice up your video presentation:
  1. Rearrange your pictures.
    The storyboard shows little thumbnails of your pictures - this makes it easy to rearrange, move, and delete pictures from your movie. Just click on the thumbnail with your mouse, and drag it into position.
  2. Rotate your pictures.
    Some of your pictures may be rotated wrong (if you held your camera sideways for a vertical photo). Fortunately, Movie Maker has a series of rotation video-effects that will fix this. Simply open up the Video Effects collection, and drag the rotation effect onto your picture in the storyboard to make it right-side-up.
  3. Fix your pictures.
    The video effects that come bundled with Movie Maker will all work on your pictures as well. That means you'll be able to perform basic photo manipulation ... for example, you could lighten or darken your pictures if they aren't exposed properly.
  4. Add transitions.
    You can add transitions between each of your pictures by dragging the transition effects onto the storyboard. Most of the included transitions are rather "over-the-top," but they look great with pictures.
  5. Add music or a voice track.
    You can easily add a music track, or narrate your photo video. You'll need to do one of these things because your movie won't have any sound otherwise.
There is one thing you should keep in mind when laying your pictures onto the timeline ... and that is picture duration. By default, when you place a picture on the timeline it will stay on the screen for 5 seconds before moving to the next picture. When you start add transitions (which take time, themselves) this time drops down to around 3 seconds. This may not be enough time for you, especially if you are trying to narrate your slideshow, so you may need to change the timing of each of your photos.
  1. By going into the timeline view and "trimming" each picture. Simply grab the beginning or end of each picture and drag it to the desired length.
  2. By changing your timing options. You can change the default 5-second duration to any length of time you like ... you could even set your duration very short in order to make your own "stop motion" movie. Simply go to the menu bar, and click [tools - options], then click on the advanced tab and change this setting. Note that this duration change only effect new pictures as you lay them on the storyboard ... and won't effect the pictures you've already placed into position.
Dec 04, 2010 | Computers & Internet
I got a film which I like very much, but I want to cut the last 2 minutes down, I used Windows Movie Maker, but it didn't support MP4 format videos. How can I edit mp4 videos on my computer? Maybe you can try another video editor - AVS Video Editor. It is a professional video editing program which can create your movie with a few simple drag-and-drops and enhance your videos so that they have professional look. It also supports almost any popular formats such as files in AVI, MP4, WMV, 3GP, QuickTime, DVD, VOB, etc. Now we come to learn how to edit MP4 videos with AVS Video Editor. Step 1: Download and install AVS Video Editor Download AVS Video Editor, run AVSVideoEditor.exe and follow the installation wizard instructions. Step 2: Launch AVS Video Editor and load your MP4 video Run AVS Video Editor. A new empty project will be created automatically. Press the Import button within the Main Library pane to load the MP4 video file: Select your MP4 video and press Open: The selected MP4 video file will be added into the Video category of Main Library: Step 3: Add your MP4 video to the Timeline To apply different effects to your video, you should place it to the Timeline area, first of all. So, select your video in the file area (enter the Video category if you are not in it) and without releasing the left mouse button drag it to the very first row of the Timeline and only after that release the button to drop the video there Now all the preliminary actions are done and you can proceed to add transitions, apply different effects, lay text and other videos over the main ones, dub episodes and create DVDs with menus. More information ,please have a close look at the video editing software
Jul 19, 2010 | Computers & Internet
221 people viewed this tip
David Payne
David Payne
