Tip & How-To about Office Equipment & Supplies
Error on the front panel of the printer "LCD List needs to be upgraded"
You may be able to scan from hp solution centre , but not from front panel.
the very first steps is to check the destination folder and if it is not prefilled.. fill it.
2. do a semi full reset .. and then L2 uninstall and reinstall .
After each step you have to try scanning before going to the next step.
I have a HP C5580 printer and I can not scan to email. Do you have a solution for me Thanks Audrey
Step 1: Configure Windows Mail.
http://windowshelp.microsoft.com/Windows/en-US/help/00e419ef-fee2-472c-ad02-b14331571a521033.mspx
OR
http://www.apluskb.com/scripts/How_do_I_configure_Windows_answer3578.html
Step 2: Go to IE>Tools>Options>Programs>Email> Select Windows Mail
Step 3: Set Windows Mail as the default e-mail program
  1. Open Windows Mail by clicking the Start button, clicking All Programs, and then clicking Windows Mail.
  2. Click the Tools menu, and then click Options.
  3. Click Make Default next to This application is NOT the default Mail handler. If the Make Default button is not available, then Windows Mail is already set as your default e mail program.
Step 4: Populating E-mail program as scan to destination
  1. Open HP solution center.
  2. Click on Settings.
  3. Go to E-mail Settings.
  4. In the E-mail settings box, select the e-mail program to Windows mail and click apply.
Step 5: Change the Setting “Scan to” in Solution Center
  1. Open HP Solution Center, if it is not already open:
    • Windows VISTA: Click Windows Icon, click All Programs, point to HP, and then click HP Solution Center.
HP Solution Center opens in a new window.
  1. In HP Solution Center, click Settings, and then click Scan to...Setup. The Front Panel Destination List Setup window opens.
  2. From the Available Scan Destination list, click the program you want to be the scanning destination, and then click the Add button. The program moves to the Front Panel Destination list.
Note: You can also move the program to the top of the Front Panel Destination to scan to that destination automatically.
  1. If you do not want to change any other settings, click OK to close the Front Panel Destination List Setup window.
5. Check the functionality.
Feb 10, 2010 | HP Photosmart C5580 All-In-One InkJet...
SCANNING ISSUE
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Jun 28, 2009 | HP LaserJet 3050 All-In-One Printer
multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
Click Update .
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
all leds light on panel
Click Update .
Apr 27, 2009 | HP LaserJet 1300 Printer
can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
192 people viewed this tip
k24674
jasbo
jasbo
