Tip & How-To about Apple iPhone 3G
How to save time in driving directions using Iphone
One of the uses of the iPhone’s Map application is to get driving directions, right?. The starting point and destination point fields offer the Bookmarks button, you can quickly use a bookmark, recent location, or contact when searching for directions. For me, the first thing you should do in Maps is to find your address your own address and then bookmark it—this will make finding directions to and from locations as easy as tapping your home bookmark
Apple iPhone 3G Logo
how to reboot the iphone a1241
Back up you Data to a disk
First make a folder in My documents click start all programs accessories My Documents open then right click select new folder and name it iPhone back up for an easy location find.
You will need to connect your iPhone to a computer once connected Click start all programs accessories open windows explorer navigate to your iPhone it might be listed as a mass storage device open it up you should see all of the data inside. or click start click on computer you should see your drives and your iPhone Right click on the data you need to be saved right click select copy navigate back to the destination drive it could be a another drive or C: drive in my documents right click select paste or hold the mouse cursor the Data drag them to destination folder then drop the Data in to your newly made folder iPhone back up. If you need more help with this post a reply
Hope this helps.
Jan 04, 2013 | Apple AT&T A1241 IPHONE 3G 8GB CELL PHONE
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
no maps found
When your tom tom comes up with the no maps found error message. There are several causes to the problem.
If you updated your map using the latest map guarantee and then get the error No maps found, make sure you install the latest version of the TomTom application.
Check for the latest application: Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
You can check the version of your application in TomTom HOME. Connect your device and then click Manage my device and select the Items on my device tab. Expand Applications and then click More info.
Your map may require the latest version of the TomTom application.
Check for the latest application Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
HOME may not immediately offer the latest application version when installing a downloadable map on a blank memory card. Re-connect your memory card to HOME and check for the latest application by clicking Update my device in HOME. HOME this time offers the latest application for your device. Try Installing maps on a new memory card
You need to also make sure all files are in the right places. Browse the content of your navigation device:
Windows XP: Click Start > My Computer and then double-click the removable drive of your device.
Windows 7 / Windows Vista: Click the Windows start button > Computer and then double-click the removable drive of your device.
Mac OS X: Double-click the desktop icon of your navigation device.
Check the following:
The map folder (e.g. Western_Europe) needs to be located in the root directory of your navigation device or memory card. This means the map folder may not be inside another folder. Before you move the map folder we recommend that you create a manual backup.
The map folder needs to contain at least the following files
cline.dat cname.dat cnode.dat faces.dat mapinfo.dat poi.dat tables.dat tmccodes.dat traffic.dat .meta (map v705 or higher will have/need this file) .meta.dct (map v705 or higher will have/need this file) .pna
If any of these files are missing restore a previously made backup or re-install your map to your device (in TomTom HOME click Add Traffic, Voices, Safety Cameras etc. > Items on my computer).
Hpe this was helpful. Thanks for using fixya.
Jan 26, 2011 | Tomtom ONE GPS Receiver
Map updates. The directions are often incorrect. Device voice and map show me I am at destination then changes to show it is actually a half mile or more down the road. Needs corrections!!!!!!!!! Thanks!
There ar frequent minor map corrections accessible through MapShare. You configure your GPS to accept these corrections. You can selected to accept ALL, or from TRUSTED sources, or ONLY corrections verified by TomTom.
Connect the unit to the computer and download the MapShare corrections. If your map is too old, maybe it is time to get the latest one.
If you have started using your unit not long ago (less than 30 days) you may have the right to a free update. TomTom offers the 30 day latest map guarantee.
Connect the unit to a computer where you installed the tomtom HOME application. Upon registration, HOME will proceed to update your GPS.
Jan 06, 2010 | Tomtom ONE XL GPS
When i type in destination, I get map view instead of arrow pointing direction and showing which way to turn ect.I've tried everything to get back to driving directions , follow the arrow in the direction intended. Please help I can't follow map view.
depends on which TomTom Go you have (maps preloaded only go700 and go910 no memory card slot)
This is for Go910
Tap Change preferences in the Main Menu.
(When you first start using your TomTom ONE XL, not all the buttons will be shown in the menu. Many buttons and some more advanced features are hidden because you will not need these features very often.To see all of the buttons and features, tap "Show ALL menu options" button in the Preference menu.)
then Tap "Turn off map display" button to turn off the map. Instead of seeing your position on a map in the Driving View, you will only see information about the next instruction.
you can download all TomTom manual
go to tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
20/Apr/09
Apr 04, 2009 | Tomtom GO GPS Receiver
1,434 people viewed this tip
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
