Tip & How-To about Intel DG965WH Motherboard
CD DVD NOT RECOGNIZED
In the BIOS, set the disk controller to Legacy mode if mobo doesn't recognize IDE CD/DVD Drives.
Intel DG965WH Motherboard Logo
I have a new mobo and I have only one IDE connection and I have about seven SATA connections. I have two IDE harddrives and two IDE CD/DVD-RW drives which are using the IDE connection on the MOBO. I purchased two IDE-to-SATA adapters and connected them two the HDD's and now I cannot seee the drives. I am not sure what to do now. can you help? Elise
If you are doing this in windows xp, you will need to install the scsi drivers that are for your chipset (the motherboards traffic control basically) These are on the cd that came with your mobo. Another thing you can try is to set the bios to ide emulation mode (probably called safe mode/compatibility mode) for the sata channels.
Hope this helps
Jay
Jul 08, 2009 | Office Equipment & Supplies
Dell Dimension 2300 does not recognize LG GCE-8160B DVD/CD RW ROM.
If IDE drive, you may have to set disk controller to legacy mode in BIOS.
Apr 24, 2008 | Computers & Internet
computer problem
your OS HAS GONE CURRUPT...RQURES A REPAIR AND IT WILL BE OK, BEFORE REPAIR JUST LOOK IN DEVICE MANAGER THAT ITS AVAILABLE THERE.
Apr 14, 2008 | Intel Motherboard
SATA Drivers for Hitachi HDD
Is there a BIOS setting to temporarily put the SATA controller into legacy mode? XP would then think it's an IDE drive. Then, after installing XP, install the drivers from the motherboard CD, then go back into the BIOS and turn off legacy mode.
Jan 13, 2008 | Computers & Internet
2,051 people viewed this tip
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
