Tip & How-To about Sony PlayStation Portable (PSP) Console
How to Get your PSP "Online"
Getting "online" can mean many things, so I'm going to try and answer them all.
Getting on to a Wi-Fi network.To get onto a Wi-Fi network, just scroll all the way left to [Settings] in the home screen (XMB), then to the bottom to [Network Settings]. Then choose Infrastructure Mode, then [New Connection]. If you know the ID of your network, go Manual, but most will want [Scan]. Choose the desired Network out of the list to continue. It may need a security key, which you can enter at a later screen. When you get to the end of the wizard, you press Circle to save the connection, then you can Test it on the next screen. You are connected, and can use that Wi-Fi network for any Internet Functions on the PSP.
Joining PSN:To join PlayStation Network on the PSP, scroll all the way to the right of the XMB, to the PSN icon, then choose PlayStation Store, it should prompt you for an account, then follow the prompts to create one. You can also head over to playstation.com and somewhere at the top of the Page there should be a Sign In/Sign Up option for PSN. Again, follow the prompts, then enter your newly created login details into your PSP when it asks.
For Online Gaming:This procedure is very different for different parts of the world. I'm an Australian, so I'll use the Australian method, which is the same for Europe. North America uses a very different method, so you should check your local PlayStation.com.
Australia/Europe:Unless you are using a very new Game, most games online functions will ask for a "Handle" and "Password". To get one of these, look in the packaging for your PSP for a small code (two parts of 7 digits). Once you have that head over to yourgamingname.com, choose your country, and enter your code on the right where it asks. Then it will give you a Handle and a Password, you can enter into your PSP Game's Multiplayer section to get online.
Sony PlayStation Portable (PSP) Console Logo
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Wifi saying unable to scan networks
Hello!
Here are the things you can try for a malfunctioing Wi-Fi on your Galaxy S:
Try turning off your Wi-Fi then turn it on again.
  • Sometimes, this works for me as the Wi-Fi might need a restart so it can try scanning again. You can do so by going to Settings > Wireless and Network > Wi-Fi Settings and ticking the Wi-Fi checkbox.
Turn off your handset then turn it on again.
  • An app that was running on your handset might be messing with your Wi-Fi, so to make all things better, you can restart your handset for a fresh boot. :)
Check if there are actually Wi-Fi networks in your area or the Wi-Fi is too weak.
  • If there aren't any Wi-Fi networks to detect, it can't do anything at all in the first place. Try moving to an area with better Wi-Fi signal.
You can ask me if you have any queries! :) ~azukibean70
Feb 23, 2011 | Samsung Galaxy S GTI9000 Smartphone
Blackberry Bold use Wi-Fi network or mobile first
Yes, the Bold 9700 will use wi-fi in preference to the mobile network whenever both are available. I had one for a month, it was my primary means of internet access and I didn't get charged a penny for any data usage. I used it on both my home wireless network and in many public hotspots.
In any case, it's easy to check: the top of the screen will show the wi-fi logo in white when connected and greyed out when wi-fi is switched on but not connected.
I hope that this answers your question, if so then please take a moment to rate my reply. If not, then please add a comment and I shall expand upon my answer to suit your needs.
Mar 31, 2010 | RIM BlackBerry Bold 9700 Smartphone
just a basic how to about putting psp online
How to connect the PSP wirelessly
Go to Settings and locate Network Settings. Under Network Settings, choose Infrastructure mode. Click X and then choose New Connection. You will have three options. Scan, Enter Manually, or Automatic. For this how-to, let us choose Scan. Click X to start scanning for the available wireless network. Once your wireless access point is detected, click the right button on the four-way controller to accept the default settings for the connection. I am presuming that your wireless network doesn't have WEP or WPA enabled. Accept the settings and then if there are no problems, you should be able to connect to the internet using the PSP's browser.
Sep 26, 2009 | Sony PlayStation Portable (PSP) Console
im a newbie to psp how do i get online
Getting on to a Wi-Fi network. To get onto a Wi-Fi network, just scroll all the way left to [Settings] in the home screen (XMB), then to the bottom to [Network Settings]. Then choose Infrastructure Mode, then [New Connection]. If you know the ID of your network, go Manual, but most will want [Scan]. Choose the desired Network out of the list to continue. It may need a security key, which you can enter at a later screen. When you get to the end of the wizard, you press Circle to save the connection, then you can Test it on the next screen. You are connected, and can use that Wi-Fi network for any Internet Functions on the PSP.
Joining PSN: To join PlayStation Network on the PSP, scroll all the way to the right of the XMB, to the PSN icon, then choose PlayStation Store, it should prompt you for an account, then follow the prompts to create one. You can also head over to playstation.com and somewhere at the top of the Page there should be a Sign In/Sign Up option for PSN. Again, follow the prompts, then enter your newly created login details into your PSP when it asks.
For Online Gaming: This procedure is very different for different parts of the world. I'm an Australian, so I'll use the Australian method, which is the same for Europe. North America uses a very different method, so you should check your local PlayStation.com. Australia/Europe: Unless you are using a very new Game, most games online functions will ask for a "Handle" and "Password". To get one of these, look in the packaging for your PSP for a small code (two parts of 7 digits). Once you have that head over to yourgamingname.com, choose your country, and enter your code on the right where it asks. Then it will give you a Handle and a Password, you can enter into your PSP Game's Multiplayer section to get online.
Sep 24, 2009 | Sony PlayStation Portable (PSP) Console
815 people viewed this tip
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
