Unable to clean Error 46
Here's the instruction for ALL brother inkjet printers (mfc/dcp is equal) when printer shows unable to clean (error 46)
You need a new ink absorber box which can be purchased from a brother service partner near your home.
Search the brother homepage of your country:
www.brother.com (choose your country)
If you have got the spare part (ink absorber box) you have to open the printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google for translation german)
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
press 8 0
press 2 7 8 3
Press stop
Did you find this Tip Helpful?
Can you Help with these Printers problems?
Brother MFC-210C All-In-One InkJet Printer
black ink wont work
black ink wont work
hello thanks for your help. i... Answer This...
Using scanner function only
Trying to use the scanner... Answer This...
error printing
error printing
my printer works perfectly but... Answer This...
unit will not turn on when...
The area under the scanner... Answer This...
Sponsored Links
Repair Service
Find Printer Repairman Near You:
