Tip & How-To about Microsoft Excel for PC
How to find no. of rows and columns in Worksheet.
Hello everybody, this would be my first tip on FixYa.com. Number of people might not be aware how many rows and columns are there in Microsoft Worksheet.
This is how you can find out.
1. Select A1 cell in the worksheet
2. Now press Ctrl + down arrow from your keyboard, that will take you to the bottom of the row. You can find the number on the left side.
3. Again select A1 cell in the worksheet and press Ctrl + left arrow from your keyboard, that will take you to the last column of the worksheet. Now to number, just type "=column() " , without quotations, that will give you the number of the column.
Microsoft Worksheet columns is number from A to Z, again from AA to AZ, again from BA to BZ and so on till it reached IV in Excell 2003 and earlier version.
Microsoft Excel 2003 and old version has 16,777,216 cells per worksheet (65,536 rows * 256 columns).
Excel 2007 has 17,179,869,184 cells per worksheet (1,048,576 rows * 16,384 columns).
Microsoft Excel for PC Logo
XLS SPREET SHEET
According to the following article, "There are over 1 million rows available in XL 2007 and 2010 - 1,048,576 to be precise - and over 16,000 columns", and "Arrow down+End takes you to row 1,048,576", and "Excel XP has 65536 rows"... http://answers.microsoft.com/en-us/office/forum/office_2010-excel/office-2010-excel-what-is-the-max-number-of-rows/82541ab3-bc70-42df-8345-af72a77ad8ce
Jun 30, 2014 | Computers & Internet
cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Aug 14, 2013 | Microsoft Office Computers & Internet
How to number a column. I can't remember the short formula, something like a1+1= which would make the number two pop up in the cell underneath.
You can number rows in a column by entering a number in cell A1 (usually the number 1 but youcan start with any number) and the formula (=A1+1) in the next row. The result there will be 2. Copy that formula down the rows you want to number and they will be numbered 3, 4, 5, etc. Each row adds 1 to the previous row so if you do anything that disrupts the sequence (like inserting a row between two others) you will have to copy the formulas down again to restore the sequence. You can also use the Edit-Fill-... menu command to put a series of numbers into rows. Put the starting number in th efirst row. Highlight it and the rows that you want to number and select Edit-Fill-Series... Those numbers will not change if you insert columns or move the formulas.
Or you can use the formula =ROW(A1) in any cell to return the number of that row. (The result of =ROW(A1) is the number 1 in cell A1, the result of =ROW(A2) is the number 2 in cell B2, etc. In this case inserting rows will not affect the numbering (i.e. row A5 will always be numbered 5 even if the data in it is moved down.)
Sep 18, 2009 | Microsoft Excel for PC
Access Pasting Multiple data in the table
When pasting data between tables, you have to make certain to select the exact number of rows and columns that you are going to paste into. For example, if you are pasting ten rows and ten columns of data, select (highlight in) from source table, Control C to copy, then go to destination table, select (highlight) ten rows and ten columns, then paste, either by right click and paste, or Control V.
This should solve your issue, but if not please post back. Thanks for rating FixYa!
Oct 03, 2007 | Microsoft Office Standard for PC
1,106 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
