Tip & How-To about Televison & Video
RCA Universal Remote Programming Instructions And Codes
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 to 6 again.
To Get The Code Please Go To Below Website:
http://remotefinder.rca.com/default.aspx?site=rca
You need to select the following informations from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
3.Make of the device(Philips,Sansung)
Thank you
Televison & Video Logo
i have been sturggle with remote rca to my tv sharp how i can do that ?
HI,
Direct Code Entry:
Code Search:
7. Try using the remote. If it does not function repeat steps 1 through 6
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
Thank you
Jan 25, 2011 | RCA RCRN04GR Remote Control
I have a TV/vcr combo and need the tv codes for an rca universal remote.
HI, Direct Code Entry:
Code Search: 1. Turn on the device you wish to control.
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 05, 2010 | Televison & Video
direction to rca remote.
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 11, 2010 | Televison & Video
i have rca universal remote needing to program ge tv. need instructions, please
HI,
Direct Code Entry:
Code Search:
Thank you
Aug 05, 2010 | RCA Televison & Video
i need tv codes for a philip tv to a universal remote
HI,
Direct Code Entry:
Code Search:
Thank you
Aug 02, 2010 | RCA Universal Remote Control
1,808 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
