Tip & How-To about Computers & Internet
How to make an appropriate selection in buying a computer.
How to make an appropriate selectionin buying a computer :
Desktop or Laptop
If you need a computer on the road, alaptop may serve both mobile and back-at-the-ranch use. Today,laptops are very expandable with USB ports and PC Card slots allowingfor a myriad of extra devices. The only problem may be screen sizeand keyboard. Try it first! If the screen is too small and/or thekeyboard is not conducive to long hours of typing, a full-sizemonitor and external keyboard can be attached at the home site.However, the maximum screen resolution is coming from the laptop, andthat cannot be changed unless you have a docking station that allowsa different display adapter to be plugged in. See laptop for all thefeatures.
If you wish to buy a desktop thenyou should keep the following things in mind:
Your need:
  1. Home use
  2. Office use
  3. Gaming
For Home Users:
If you wish to buy a desktop withthe latest operating system Windows 7 then you should focus a bit onthese hardware configuration:
Hard drive: 320GB or more
Memory : 2 GB ormore
Processor: Quad toduo or I3
You don't need to buy any anti virusor any other software because a lot is available free on the internetand that s sufficient.
everything else depends on yourneed.
For Office Users:
Ifyou wish to buy a desktop with the latest operating system Windows 7then you should focus a bit on these hardware configuration:
Hard drive: 500GB or more
Memory :4 GB ormore
Processor:I3 or more
Youmust have a better protection I would recommend Norton.
For Gamers:
Hard drive: 1 TBor more
Memory :8 GB ormore
Processor:I5 or more
Anadditional Video card is recommended with a dedicated memory on it.
Youdon't need to buy any anti virus or any other software because a lotis available free on the internet and that s sufficient.
Ifyou don't want to buy a branded computer you can also get itassembled that s also a fair option as you get warranty on all thecomponent you select and you have an option to design it yourself asper your need.
Ifyou are planing to go for a LaptopThen in that case you must follow the above things apart from thatyou should keep a few points in your mind:
Security- Laptop tracking
Usethe Cyber Angel security solution to track your laptop in case it isstolen.
Shocks
Becauseof they are designed to maximize mobility, laptops are prone toshocks. Always turn your laptop OFF before you move your notebookfrom a place to another, unless it is well stabilized on a stand thatis designed to absorb shock.
Computers & Internet Logo
king of the road does not run,error your computer does not have graphic accelerator?
This game requires a higher performance graphic card - unfortunately, your notebook computer does not allow for upgrades like a desktop computer would.
If you have a desktop with a higher performance graphics card, it may run. Otherwise you will have to try it on a replacement notebook computer - try it out before you buy.
Jun 14, 2014 | JoWood Productions King of the Road for...
how to coppy cassete in alaptop
To transfer the videos to your laptop you need a Firewire cable and Firewire port on your laptop. http://www.ehow.com/how_2005440_camcorder-pc-ieee1394.html
Feb 28, 2011 | Sony Handycam DCR-TRV22E Mini DV Digital...
My modem
Returning the computer to Gateway is the most reliable option, but unless you have the premium grade warranty this will be expensive.
You can buy a replacement from Best buy, but if it is for a laptop I would recommend either an external modem or a PCMCIA modem. Opening up a laptop is a job for an expert. If you have a desktop/tower PC then you can buy an external or an internal Modem, Only but the Internal modem if you feel confident about opening up the PC. The external modem is the safest to buy. You will need to check what connections you have on the back of your PC either a serial connector or nowadays a USB connection. Make sure the modem you buy is appropriate to the service you use e.g. dial up or DSL. The assistant in Best Buy should be able to help you with that.
This should fix it .
Carrie
Jul 21, 2008 | Computers & Internet
Need Help
Last Month i Purchse Laptop Compaq Presario V3702TU With Vista Home Basic. Wrongly I delete the Partition and again I Installed Vista Home Premium down load all Drivers and install only Web Camera Driver not installed kindly help me out how to installed web camera driver on vista home premium 32 bit.
Apr 06, 2008 | Compaq Presario R3000 Notebook
Network Port Replacement
You can not replace a network port [RJ45] on a Desktop PC bacause usually these ports are suface mounted or soldred to he motherboard itself. Tampering the motherboard may leave it unusable. So it is adviced that you could easily buy and install add-on network adaptors that could serve your needs. If you have a laptop computer you should consult a hardware dealer to find whether they offer any laptop solution for additional network card/port.
Sep 26, 2007 | Belkin Network connector
108 people viewed this tip
David Payne
David Payne
