Tip & How-To about Computers & Internet
Load Applications Faster... Much Faster
Hello and Welcome to FixYa.
Another Trick, tested by me on Photo Shop CS2 and got amazing result.A MUST DO!!
NOTE:This switch does not work with all programs IT WORKS WITH MOST. If you complete Step 3 and get a 'target box invalid' message, just remove the /prefetch:1, Select O.K., and all will go back to normal.
For this example, I'm going to use Adobe Photoshop. If you use it, you know that it takes a little while to load; especially if you have extra fonts, brushes, etc...loaded that it needs to read. Well, were gonna make it faster along with any other program you wanna speed up.
STEP 1: Right click on the Adobe Photoshop or any other programs shortcut and select properties from the menu.
STEP 2: In the Target: Field add the /prefetch:1 switch to the very end of the path.
So originally, the Target Field shows:
"C:Program FilesAdobeAdobe Photoshop CS2Photoshop.exe"
You are going to make it show:
"C:Program FilesAdobeAdobe Photoshop CS2Photoshop.exe" /prefetch:1
There is a space between the " and the /
STEP 3: Select Apply and O.K.; or just O.K. is fine and your change will be applied.
Do share your Experience.
Concerned, Nooh
Computers & Internet Logo
Adobe Photoshop CS2 Tryout for PC serial
Hello there,
Welcome to Fixya.
Unfortunately, we at Fixya do not provide crack keys as it is illegal. You would really have to purchase the valid license key to enjoy the benefits of a genuine software.
Aug 26, 2011 | Adobe Photoshop CS2 for PC
what is process nokia 6270 format code i used *#7370# or *#7780# its not working.
Hello and Welcome to FixYa!
If format code *#7780# or *#7370# are not working then format from the given procedure:
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone will format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
I hope this solution helps you.
Further assistance, I am here to help
Thank you and Keep using FixYa!
May 06, 2011 | Nokia 6270 Cellular Phone
autherization code of adobe photo shop cs2 serial
100% works!!! use keygen!!!
keygen cs2: http://www.dailytipz.com/wp-content/uploads/2008/12/adobe_photoshop_cs2_keygen.zip
For Adobe Photoshop Cs2
Note: Don’t Close This keygen
Note: Don’t Click Generate Serial Number
Open Adobe Photoshop keygen befor when you Install Adobe Photoshop Cs2.
Add This Serial Number When You Install
After installation active adobe photoshop by phone
Abobe photoshop display a activation number
Add activation number in adobe photoshop kengen
Your Authorization Code Display in Adobe photoshop kengen Authorization Code menu
Copy This Code And Past into your Software
Your Work Is Commplete Enjoy Adobe Photoshop Cs2.
You can see how it Work see this pic.
Apr 23, 2010 | Computers & Internet
serial number of adobe photo shop cs2 version 9.0
If you have lost the product key to your software or device, and you have previously registered the software or device, or have a proof of purchase for the software or device, contact the manufacturer and they will provide you with a new product key.
FixYa and it's experts do NOT provide product keys, serial numbers, illegal software, authorization numbers or codes, warez, hacks or cracks under any circumstances. Any expert that does so will be barred from answering questions. Those asking are subject to their membership being deleted and be barred from the site. Additional misuse of FixYa may subject you to Federal charges. Please note that IP addresses accessing this web site are logged.
Thank you for using FixYa.
Aug 22, 2009 | Adobe Photoshop CS2 for PC
need activation code
Hello.
Aug 13, 2009 | Computers & Internet
173 people viewed this tip
David Payne
David Payne
