Tip & How-To about Computers & Internet
How to enable the hidden Administrator account in Windows 7 and Windows Vista
Unlike Windows XP the administrator account is disabled by default in Windows Vista and Windows 7.
Many people prefer to have the amin account open just in case they forget their main account password or to alocate admin rights over another user account like your childrens for example.
In the tip I am going to tell you how to enable the admistrator account so it is visible on the Welcome Screen.
These step only apply to Windows 7 and Windows Vista accounts that have admin rights, they won't work on an account which is limited or which is a guest account.
1. Click on the Start Menu.
2. Click on All Programs.
3. Click on Accessories.
4. Right click on Command Prompt and select Run as administrator. An Adminstarator Command prompt window will open.
5. In the command window type "net user adminstrator /active:yes" or "net user adminstrator active:yes"(with out the quotation marks)
6. to disable the admin account type in the command window "net user adminstrator /active:no" or "net user adminstrator active:no" (without the quotation marks)
7. Close the command window.
8. Log out of your account.
When you have logged out of your account you will see the Administrator account on the Welcome Screen.
If you don't see the admin account straight away all you have to do is restart your computer.
That should be it.
Please feel free to leave a comment on this tip.
Computers & Internet Logo
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
what is default admin password for Toshiba satillite Pro C660-171
The default admin password is blank (no password)
If you're using windows 7, the admin account is disabled by default and you have to enable it.
Follow the directions here to enable it:
http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-windows-vista/
Sep 08, 2011 | Toshiba Computers & Internet
279 people viewed this tip
David Payne
David Payne
