Tip & How-To about Computers & Internet
How to un freeze your computer
You should restart your computer or turn it off and on. You can also unplug the wire and plug it back.
Computers & Internet Logo
95 GMC K1500 350... replaced distributor...timed it at 0 with computer unplugged... plugged it back in and timing changed by few degrees, engine surges and runs poorly. Checked plugwire route for interference(good). Is this a computer problem or maybe MAP sensor? New plugs, wires, cap, rotor, and distributor. Engine runs great before computer is plugged back in!!!
ok ran great before changes. right. you say unpluged computor to set timing.. yes.. do you mean the plug on the firewall passenger side that looks like a fuse holder kindof..?? (set timing connector ) (tan /blk wire)
did it run good during timing proceedure??? wont be MAP that is engine vacume has nothing to do with what you have replaced.
proceedure is to set timing . shut off engine , plug in.. then restart.
yes timing moves as per ECM specs. check that timing did no get out one tooth when you replaced distributor. retime . restart
Feb 01, 2012 | 1993 GMC Sierra K1500
The icon for my Harman Kardon speakers completely disappeared from my desktop. No there is absolutely no sound
Are the speakers plugged in, turned on?
Restart the PC.
Unplug the speakers from the PC and plug them back in.
Unplug the power from the speakers and plug them back in.
May 06, 2011 | Harman Kardon HK206 Computer Speakers
Keyboard it plugged in but not working
Try Restarting Your Computer A Few Times If Its Not A USB U'll Need To Restart
Jun 01, 2010 | Gateway 2520915 Keyboard
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
I've lost internet and was told that I need to refresh my router. How do I do that?
Sometimes your internet connection through your router fails for some reason or another, and you'll have to restart it. The simplest way to do that is just to unplug the router and plug it back in. If you still don't have a connection after that, unplug your modem, unplug the router, turn your computer off, turn your modem back on, turn the router back on and restart your computer. If it still doesn't work, call your ISP. If you want the video, go to http://www.videojug.com/expertanswer/computers-and-the-internet/how-do-i-refresh-my-internet-and-router-connection
Aug 13, 2009 | Computers & Internet
171 people viewed this tip
David Payne
David Payne
