Tip & How-To about Lands Phones
Keep your mobile battery's charge longtime!!!!
It's simple!!!!when u bought your new mobile first charge it ti 12 hour!!!some salesman say that charge ur mobile 3 or 6 hour.It is wrong.First charge of mobile is important.SO CHARGE YOUR MOBILE 12 HOUR AT FIRST
Lands Phones Logo
iphone reset takes long time at last 12 hours finsh
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 06, 2012 | Apple iPhone 4S
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Feb 07, 2009 | Sony Ericsson W910i Cellular Phone
works great for about 5 minutes then shuts off
ok... simple solution that battery is possibly defective or the camera has an issue that causes an excessive draw on the battery. digital camaras eat batteries anyways. when you bought the new battery did you charge it for at least 12 hours before the first use ?
Robert
Jan 24, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
motorola razor
try ur old battery if not ok check the voltage level of ur battery if it is 3.6 volts and mobile is still not on then may be software prob. but if have less than 3.6 volts bost ur battery with boaster if u dont have boster put ur mobile on charge for some time 30 minute if the prob is from battery this will began to charge withing 30 minute.
Mar 18, 2007 | Motorola Mobility RAZR V3
188 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
