Tip & How-To about Audio Players & Recorders
What "Protector" means
Quite often a receiver or amplifier will show the message "protection" or "protector". Other times, the unit will return to the standby mode and possibly blink the standby light. This is a protective mode that causes the shutdown of the unit to "protect" it from further damage.
Most modern electronics contain additional circuits that monitor the state of the unit. If a problem is detected, the unit is shutdown and a message of some type is displayed as detailed above. This is done to prevent further damage to either the unit itself or any external speakers or equipment.
Lets determine whether the problem is internal or external:
1) Disconnect any external equipment (speakers are the most common).
2) Power off the unit.
3) Turn it on again (this will reset the protection circuit)
If the protection message clears, the external equipment is the likely cause. Crossed speaker wires is the most common cause. If the unit continues to display the protection message, then the problem is internal and the unit will require service.
The most common internal cause is a failure of the output transistors. These can be easily replaces by an experienced service tech. Some units have complete amplifier sections contained within amp-pacs or large ICs often called STKs. They are so called because the generic part numbers for tehm are often STK-xxx. Panasonic uses large ICs with part numbers that start with SVI as well. If you are experienced with audio repair, a simple check of the transistors and the voltage regulators within the same circuit can often reveal teh cause of the problems.
Hope this helps,
Dan
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
My receiver will not turn on and the red standby light flashes. What is wrong?
Flashing standby light shows that protection mode is activated in receiver because of some problem in output amplifier section.
Please check output amplifier section and replace defective component to fix the issue.
Jun 17, 2010 | Aiwa AV-DV75
I have a str dg820 only about 2 months old. Recently went to power up and I get PROTECTOR message and it shuts down. I checked all speaker connections and they appear to be fine. It worked well for two months..
Try disconnecting everything (all inputs, outputs and speakers, make sure there is no cable plugged into your unit except the power cord), turn it on, if it still shows the protect message, you have an internal short or a burnt out component inside the unit, possibly a desoldered contact on one of the connectors which generates internal noise of such intensity that it sends the unit into the protect mode.
If, after trying the above mentioned, there's no message, some other possibilities are:
- a bad speaker or speaker cable
- a bad signal interconnection cable
- a fault in any of the other units connected to your reciever/amplifier
Hope you cand find something out...
Good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sony STR-DG820 Receiver
19,416 people viewed this tip
 Grubhead
Grubhead
