Tip & How-To about Computers & Internet
How to eject a disk from a slot drive, when you've tried everything else
This is about trying to eject a CD or DVD stuck in a slot drive.
Most computers have a drawer-based cd drive which rarely suffers from disk jams.
Some high end PCs (and nearly all Macs) have slot drives where you feed the disk into a slot, the disk is then pulled into the machine. This gives better structural strength to the case, looks neater etc etc...
The problem is that occasionally a disk will get stuck. and there’s no little release hole on the front to push a paperclip in. There is lots of advice on the internet for the Macs, the Wii, and Pioneer drives of varying types, and most of these advise OS tricks, or firmware commands, however this trick is for when all those methods have been tried, and the disk is still trapped in the machine.
The idea is to stop the disk spinning and fool the drive into thinking the CD is bad, and it will eject it. I was taught this trick by a retired engineer, and it works a treat.
Fold a piece of cardboard (I used the side of a Frosties box) lengthways twice, until it’s quite stiff... Carefully push it into the slot until it bumps up against the edge of the CD/DVD.
Start the machine, and push the cardboard firmly against the disk to prevent it spinning. Wait for the regurgitating noises, and remove the cardboard to allow the disk to be ejected.
Easy.
Computers & Internet Logo
cd stuck no way to eject
Hoping it's running XP or later.
1) Start the computer in safe mode - Pressing F8 after the boot but before it tries to start windows.
2) Select "Start in safe mode"
3) when active (fingers crossed) Choose Start - All Programmes - Accessories - System Tools - System Restore and restore to a date prior to all your problems.
4) Win Vista is similar but the System restore is in a slightly different place, but not sure where exactly
Mar 14, 2010 | Computers & Internet
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
The CD wil not eject
There is a small hole in the drive, insert a paperclip and push in to eject the drawer manually.. the disk might be stuck and jammed the drive
Dec 29, 2007 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
1,634 people viewed this tip
David Payne
David Payne
