Tip & How-To about Office Equipment & Supplies
CANON MP 145 OR EQUILENT SERIES PRINTER
CANON MP SERIES PRINTER PRODUCE BEST QUALITY OF PHOTO PRINTS WITH REFFILLED. ALL SPARE PARTS AVAILABLE IN CANON IP 1300 WHICH IS AVAILABLE IN LOW COST. (PURCHASE IP 1300 ONLY FOR SPARES - CARTIRIDGE CL-41 THAT PROVIDE MUCH HIGHER PRINTS, & COMMON SPARE PARTS MATCH WITH MP SERIES PRINTERS.) EXCHANGE THESE & EARN MORE. PLS VOTE & REPLY priyankaanta@yahoo.co.in
Olympus P 400 driver mac 10.84
Olympus has not supported that printer on the Mac in 10+ years. Also checking the Apple printer driver support page I do not see ANY Olympus printers currently supported by Apple: OS Printer and scanner software available for download
I would suggest replacing that printer with a current model photo printer (also Dye-Sub) from Canon. The Canon Selphy Dye-Sub photo printers produce flawless professional glossy prints: Compact Photo Printers
Dec 05, 2013 | Olympus P 400 Thermal Printer
waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
FD73 Photo Quality
The Camera - this is an early low rez., device not a patch on what can be obtained now.
Sep 13, 2005 | Sony Mavica MVC-FD73 Digital Camera
197 people viewed this tip
k24674
jasbo
jasbo
