Tip & How-To about Washing Machines
Washing Machine washes but no rinse cycle
Washing machine will not spin if it seems like the door/lid is opened (or seems to be opened). Hence you can check the lid switch if it is working. One test is to use a pencil and push down the switch a little further than normal. You should see the cycle starting. Replace switch or just check if it was loose and tighten the two screws.
Washing Machines Logo
my washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
The washer will not run water in or spin or do anything and it is plugged in
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Feb 16, 2010 | Kenmore Washing Machines
washer won't turn on, do I need a new door switch?
Jan 27, 2010 | Washing Machines
i just replaced the door lock because the door would not lock and now the machine will not work.
Jan 05, 2010 | GE WSXH208A Front Load Washer
Maytag MAH-24 door won't open
Apr 26, 2008 | Maytag MAH2400A Front Load Washer
206 people viewed this tip
Top Washing Machines Experts
