Home | All Products | RF30 Remote Control | Tips
Fix your dodgy remote buttons
robotek
By Guru robotek
Rank: Guru
Rating: 91%, 1163 votes
posted on Apr 23, 2008
Very Helpful
Hi.This is a guide to repair dodgy remote control buttons. This procedure is about sorting out dodgy buttons. If you remote does not go at all, they following may not help I will work several times generally, although some silicon/carbon contacts can become RS This procedure also works if you have a remote with coffee, coke, or other beverage spilt on it
You will need
  1. A med or thin guitar plectrum(pic)
  2. Methylated spirits
  3. Lint free cloth(tea towel will do).
Now I will take you through opening and cleaning the remote keypad.
  1. Remove clip on cover and batteries
  2. Slip the guitar pic under the edge of the remote.
  3. Run it around whilst gently levering the cases apart
  4. It will open with some patient effort and then pretty much fall to pieces
If the remote HAS HAD A DRINK..... wash all parts in warm mildly soapy(dishwash in kitchen sink). DRY PCB IN THE SUN, or on TOP OF A TABLE LAMP.
Dont dry the plastic casings this way... they can melt!! Just leave them in the open air
  1. Clean the pcb/contact board by gently wiping with the cloth moistened with metho
  2. Clean the silicon rubber button contact pads.
  3. Be sure that no bits of lint or residue are left on either the pcb or the contact rubbers.
  4. Let dry for 15 mins to be sure no condensate moisture or metho is left on boards or button assly
  5. Reassemble by layering parts and clip together
  6. check that terminals are not corroded. Use an emery nail file to buff them up if there is corrosion. Spray contacts with CRC2-26 or WD40
  7. Reinsert batteries(fresh ones) and test on appliance. You can also see a remotes Infrared LED flashing when it is working by viewing it with a a phone camera, or camcorder
This process will cure most dodgy button problems. If they are still not good, try the process again.... or a new rubber contact sheet may need to be fitted. In the case of universal remotes, cost will probably dictate buying a new one anyway.Good luck and go FixYa!!
If your remote still has problems there are yet other cures. I will post more as time allows. ;)
ask Robotek
Was this helpful?
Yes
No
2 people thought this was helpful
Comment #1
posted on Feb 05, 2009
GP49
By Master GP49
Rank: Master
Rating: 99%, 34 votes
Some have reported problems taking apart the very common WHITE DirecTV remotes. It's really easy. Take off the battery door and remove batteries. Remove the two visible screws. Now take a sharp-tipped knife or similar tool and pry off the grey panel on the front of the remote. Remove the four screws thus revealed. Now the two halves of the remote are easily pried apart with a butter knife or similar, and you can easily access the keypad and circuit board to follow Robotek's suggestions.
Can you Help with these Remote Controls problems?
Universal RF30 Remote Control
Have bought a "one for all" universal remote but...
I have a SANAI URC-82E Universal Remote Control, the...
Need Codes for Nexxtech 6-in-1 Universal remote cotrol...
need some codes for this remote
I have a sanyo tv and have lost the codes to one for all...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
