Tip & How-To about Microsoft Windows Vista Ultimate Edition
Program or game not working properly?
Try to Enable Application Compatibility-Mode for the game or application. right click your game executeable file then properties Compatibility, put a x on the box and select xp. apply and ok. if that doesnt solve the problem try another windows version from the list. you can also try the other options shown in the window.
Microsoft Windows Vista Ultimate Edition Logo
I have windows 7. How do I use the software supplied with hitachi dmp460 as it does appear to be compatible.
Hello and Welcome to FixYa!
You can change the compatibility of the executable file by the following procedure.
  • Right of the executable file (*.exe) and Select "Properties".
  • Click the "Compatibility" Tab appearing in the top of the window.
  • Check the "Run this program in compatibility mode for".
  • Select the desired OS (Operating System) from the drop down menu and click "Ok".
(Select Windows XP option, If you are sure that the given applications works with that Operating System).
Now try to execute the application, you are trying to Install....
Best of Luck,
Do RATE my solution, If found helpful.
Regards.
Apr 13, 2010 | Sprint Hitachi P300 Cellular Phone
Mathcad 13 installs but won't run on Windows 7. Mathcad 14 won't install on Windows 7. Any solutions?
Run it in the compatibility mode. Right-click on the executable, choose "properties", then the "Compatibility" tab. Check "Run this program in compatibility mode for". Choose the latest version of Windows the program ran on, check the screen setting that applies for your application and click "OK". Now you can start the application!
Dec 19, 2009 | Mathsoft Mathcad 14 for Windows Full...
cant install a game on my cumputer
try running (or installing) this game (whatever it is) in compatability mode.
To do so:
  1. Open Windows Explorer.
  2. Location the application executable.
  3. Right click the executable and click the Properties option.
  4. Select the Compatibility tab.
  5. Select the Run This Program in Compatibility Mode option.
  6. From the drop-down list, choose the operating system i.e. XP or win2k
  7. If necessary, select the option to run the program as an administrator.
  8. Click OK.
hope this works for you
Jul 13, 2008 | Dell Dimension C521 PC Desktop
roller coaster tycoon 3
( THIS IS ONLY FOR RCT3 AND RCT3 deluxe only ) Install the game when it is done (dont run it) Downlaod winzip 14 at http://www.winzip.com/downauto.cgi?o=1&file=http://download.winzip.com/winzip145.exe&email=your%20email&er=f When you have downloaded it go to C Drive in my computer and go into program files find atari click it and then go into Rollercoaster tycoon 3 folder find RCT3 application Delete it out of the folder. Then go to http://www.4shared.com/file/giJlaWU_/RollerCoaster_Tycoon_3.html?err=no-sess Download now then when it has finished downloaded open that zip folder and you find 3 files and go into Roller coaster tycoon 3 folder the file with Application drag and drop that only file into the rollercoaster tycoon 3 folder in atari when you have done it exit every thing if you have normal RCT3 then it should work, Now im going to tell you how to fix Deluxe edition basically do the same as what i said but now go to http://search.4shared.com/q/1/rct3plus.zip Download it, when it is done drag and drop that zip file into winzip and find the file that says application before that delete the application in Atari rct3 folder and find the application RTC3plus delete that one and replace it with the application in winzip and drag it and drop into the folder and there you are alllll done and it should should should work. Dont listen to these **** that say its registry problems and dont download any registry clean up programs you doo not need them. Hope it works Good Luck !!!!!!!!!
Jun 13, 2008 | Computers & Internet
hospital tycoon
Try to Enable Application Compatibility-Mode for the game. right click your game executeable file then properties Compatibility, put a x on the box and select xp. apply and ok. if that doesnt solve the problem try another windows version from the list.
Apr 22, 2008 | Microsoft Windows Vista Ultimate Edition
1,429 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
