Tip & How-To about Computers & Internet
How to reformat a window xp
First nsert the Windows XP disk, and turn off your computer...Turn on your computer...A screen will come up during the boot and tell you to press any key to boot from CD, (if not you will need to change the start up sequence in the BIOS). Press any key you like....Second, you are asked which file system to use, the FAT Filesystem or NTFS Filesystem. NTFS Filesystem is the newer and faster one, so use that. FAT would also limit you to small hard disks..It might take a while. Once everything is loaded, there will be a few options on the screen. The one you want says 'To set up Windows XP, press enter.' So select it and press enter.It might take a while. Once everything is loaded, there will be a few options on the screen. The one you want says 'To set up Windows XP, press enter.' So select it and press enter.Alternatively, if you just want to format a secondary hard drive you can go to 'My Computer', right click on the drive and press format and follow the instructions accordingly.
Computers & Internet Logo
windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
Jul 07, 2011 | Computers & Internet
I am trying to reload Windows on my netbook using a recently purchased disc drive. The information from Ees is not coming up on the screen....I've tried a number of things and want to know some keys to use to try rebooting.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Oct 08, 2010 | Microsoft Windows XP Home Edition
how to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
209 people viewed this tip
David Payne
David Payne
