Tip & How-To about Cell Phones
How to replace the lcd of n73
First remove the back housing then the front housing after removing the front and the back housing ,remove the battery,sim card and the memory card after that remove the screw using a tool that is compatible to your screw then after you removing the screw.Now push your plastic shim into the join at the top of the phone to lift the front cover out slightly. Then run the plastic shim along both sides of the cover to unclip it at these points too... Now have the front cover removed, like below...The LCD screen is held in place by a metal frame which needs to be unclipped around its edge for removal.The LCD screen will now be loose and can be removed. It will be attached to the phone by a ribbon which attaches like a plug and socket. Simply lift it upwards to unplug it.You can now lift away the LCD and replace with new. Reverse the whole procedure for reassembly..thats all thank you
Cell Phones Logo
sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
How do i remove the sim card of my motorola mb810?
To remove your sim card from your motorola mb810, simply open the back cover of your phone,you will see the battery, memory card etc. all you have to do is remove your battery and your sim is right there,you take out the sim and recouple the phone back till you decide to put back your sim.
thanks.
Sep 15, 2011 | Cell Phones
change sim card
to change the SIM card just remove the back cover. You should see the memory card just below the battery. Remove the battery to see the SIM card.
May 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I cant find a link anywhere on how to get the housing off of my Motorola Sliver L7. Can someone help
To remove housing off this phone is quite simple.
step one: remove back and battery and sim card
step two:unscrew all visable screws
step three:carefully take a cell phone opener tool and pry off the front housing. and the back should pop off once the front is off
Sep 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
187 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
