Tip & How-To about Video Game Consoles & Games
PS3 not reading discs
Many of you know the horrors that fall on the older generations of the ps3 20/40/60gs, mostly it is an issue with the blue ray drive where discs cannot be read.
Signs of this are as follows the game cd icon doesn't appear in the game list when one is inserted, or if a disc is in the tray the spinning icon in the top right corner continues to "scan" for the disc. These are signs of either a bad drive and needs to be replaced or the disc drive tray is misaligned, but fear not sometimes the smallest fix does the job.
I have the original 60g ps3 about half a year after my warrenty expired my blue ray drive decided to not read any form of disc be it dvd/cd/bd so i called sony they sent the coffin and i sent it back and when it arrived they had replaced the tray and parts of the drive to function again, so far so good discs reading again yay...not for long.
About a month later it happened again i was angered thinking that i just paid 180 to fix it i didnt want to spend that money again so i found a solution that seemed to work and hasn't had any problems as of yet..(knock on wood) but this being about 1 yr later im happy. Basically i figured it could be a bad sector of my hdd that is preventing my drive from reading anything so i reformatted my system and then voila! reads discs again so instead of calling sony right away try and reformat the system to its factory settings may be a pain for some and ok for others that have a large enough usb stick or drive to back up to but it saves you the cash in the end hope this helped anyone with this problem
Video Game Consoles & Games Logo
M lg bp145 quit playing blue rays but it will play dvds. Why?
Blue ray DVD's are read by a Blue violet LASER. I know that sounds pretty obvious but the colour blue is closer to the upper end of the spectrum and therefore has a shorter frequency and therefore you can generate and read much narrower data tracks. DVD's and CD use an older technology and use Red laser light which has a much wider and therefore less compact track size. So with a lower track density you get less information on a DVD.
The blue laser can be used to read both formats (and CD) but when reading the Blue ray disc the accuracy required is far greater to hit the track. Tracking errors caused by worn gears steppers and spindles can cause the Blue ray to miss the track but still have enough tolerance to read the much wider DVD/CD track.
The laser head isn't one laser, it actually produces two separate wavelengths, one for Blu ray discs and one for Red ray (DVD/CDs)
You can have a condition where the "blue-violet Laser diode fails but the red laser diode is still working. In this condition, it will exhibit exactly the effect you are experiencing.
Apr 14, 2015 | LG Televison & Video
i put in blue ray disc and ps2 games but the ps3 won't play the discs what may be the problem?
1. Ps3 does not play ps2 console games. the problem you have is the blue ray player has failed.
unfortunatly it cannot be fized, you will need to take the console to have the blue ray reader replaced.
Any further questions feel free to ask.
Nov 19, 2010 | Sony PlayStation 3 40GB System
Driver issues with Blue ray discs
Download VLC Player and, install
Dec 21, 2008 | Computers & Internet
i have three blue- ray disc which will not play. Have return these disc several times to merchant for exchnage with no success.
Your firmware seems to be an older version. Since the discs that you are nameing are asking for Blu-Ray 1.2 support.
Samsung has provided updated firmware to support these discs. Follow the instructions on the link.
http://tinyurl.com/54a9wo
(Using tiny url for ease of use)
Jun 15, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Next Gen Blu-Ray Disc Players
My BDP-S550 HDMI has no sound coming from it, the video is fine.
May 23, 2008 | Sony BDP-S300 Blu-Ray Disc Player
344 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
