Tip & How-To about Cell Phones
How to unlock your Samsung D900i
Make sure to back up all ur data and files, apps before performing these steps.
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878#
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert only a half of it,
Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language)
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.push the sim fully in at this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
7. Now Disable network lock By typing: #7465625*638*00000000#
Phone is unlocked
Just thought this may be useful for someone,
Cell Phones Logo
How do I reset my I-pAD back to original factory settings
1. On the Home screen, tap "Settings" to bring up the Settings screen. 2. Tap "General"
3. And then tap "Reset". This brings up the Reset screen which will give you the following options. a. Reset All Settings - this resets all your settings back to factory default but does not erase your content data. b. Erase All Content and Settings - this resets all your settings and erase all your content data. You might want to do a sync with iTunes before performing this erase if you want to keep any music or apps that you have downloaded. c. Reset Network Settings - this deletes your Wi-Fi network settings. d. Reset Keyboard Dictionary - this clears any history in the dictionary such as the history of the keyboard suggestions that you've rejected or accepted previously. e. Reset Home Screen Layout - this simply resets your Home screen icons back to the original default layout. f. Reset Location Warnings - this erases any location preferences that was set for your apps. For example, GPS-aware apps often popup a location warning asking if you want the app to be aware of your current location. Your answers to these questions are stored by your iPad for each app. This reset will erase these answers so that the app may popup the prompt asking for your location permission again the next time you use it.
4. After selecting one of the above options, the iPad will ask for confirmation that you really want to perform the reset. If yes, confirm by tapping "Reset".
Jul 16, 2014 | Apple Ipad I-pad
how to format nokia c1-01
Follow these steps below to perform a factory/hard reset to your Nokia C1-01:Step 1. Select Menu.Step 2. Select Settings.Step 3. Select Rest. factory sett.Step 4. Your Nokia C1-01 will go back to the state when you take it from the store.Important Notes:1. To reset only preference settings, but keep all personal data, such as contacts, messages and media file, select Restore settings only (or Restore sett. only or Settings only).2. To reset all preference settings and delete all personal data, select Restore all (or All).3. Enter the security code before the restore, if you have never changed your security code, then enter the default code 12345.If your Nokia C1-01 still requests a security code or if you forget , please bring it to the nearest Nokia Care point for inspection.
Whether it's helpful to you or not?
Thanks for using FixYa
Apr 26, 2012 | Nokia C101 Cell Phone
i have nokia 5800 mobile and its gets hanged up or gets freezed when once keypad gets locked.when i try to unlock it the screen gets blurred.
Try to bring ur phone in to factory settings by formatting, to format it follow the steps below but perform this on ur own risk and take a backup of ur data before performing.
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting. .
Jul 12, 2010 | Nokia 5800 XpressMusic Smartphone
After restarting my 5800it just stuck in the normal screen& phone is not responding to any button commands
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jul 09, 2010 | Nokia 5800 XpressMusic Smartphone
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a hard reset
1.
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
3.
Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
119 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
