Tip & How-To about Computers & Internet
Sound skipping and dragging from laptop
Try IDE drivers. My had the same problem and I couldn't figure it out.
Computers & Internet Logo
My DVD driver couldn't burn a DVD but it can burn a CD. it can also play a DVD and CD. It also detect a writable DVD but it couldn't write any DVD.
You have Problem with your DVD writter Driver Software.. try the latest and Ultimate version of Nero. thanks
Sep 01, 2011 | Computers & Internet
The motherboard k8v-x support IDE Disk over 80 GB?
Yes, it will definitely support +80 GB of Hard Disk Drive. I've tried myself with 160GB and it worked perfectly, but I am not sure if 1Terabyte will work (just curious since I couldn't get a 1tb IDE HDD). No doubt if you are upgrading to 120GB or 160 GB.
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 15, 2011 | ASUS K8V-X Motherboard
I think that the wires to the disk driver are in the wrong place, whats the right way they go in
Primary IDE Connector with Hard-Disk Drive To connect the PC-DVD drive to the primary IDE connector with the hard disk, perform the following steps:
  1. Back up the files on your hard-disk drive before you proceed.
  2. Set the jumpers on the PC-DVD drive as slave and the jumpers on the hard-disk drive as master (see Figure 11).
  3. Connect the power cable and IDE data cable to your hard-disk drive as shown in Figure 13.
Figure 13. Connecting the PC-DVD Drive to a Primary IDE Connector with Hard-Disk Drive
May 23, 2010 | E-Machines T2042 PC Desktop
IDE Primary Master/Slave NONE
Hook the two together on the one working IDE connector. Put your hard drive as the first device on the ribbon cable and make it the master using the jumper at the back. Hook the DVD to the second and set it's jumper to slave. Install your OS then try to figure what's up.
Jan 03, 2009 | Abit KD7-G Motherboard
Fujitsu-siemens Amilo pro v3515 Pent T2080 linux installation problems
please i want the all drivers download for fujitsu siemens amilo pro v3515
Apr 01, 2008 | Fujitsu Siemens CELSIUS Mobile A Notebook
178 people viewed this tip
David Payne
David Payne
