Tip & How-To about Computers & Internet
How to reset bios password on basically any pc
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Computers & Internet Logo
clear bios pass
Hello Seb, try removing the toshiba motherboard battery run the PC and it will ask for a new password (sort of) or try cmos jumper. If you can provide more info on the unit better. try google search for clearing bios password.
Jan 02, 2014 | Toshiba Computers & Internet
password the bios setup for acer aspire 6530
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Although on some motherboards the Cmos battery is soldered in
Code:
DEBUG hit enter-o 70 2e hit enter-o 71 ff hit enter-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
also
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of tenhope it helps
Apr 25, 2012 | Acer Aspire 6530-5143 Notebook PC
When ever i power up my toshiba satellite laptop,there are two blank screens with a blue box in the centre saying enter password
the bios passowere has been engaged go to bios by pressinfg del or F1 button on startup go to bios setting password you will see enter password press button with passord blank again it will ask for confirm password enter blank password press enter it will delete all the password if you are un able to enter bios and asking for password remove the cover you will see three jumber pins near ur cmos battery pin one and towo are for normal pin 2 and 3 for clear comos in some there are only 2 pin short the pin to clear the cmos some times shorting doest start the computer dont worry put the jumbers back to the normal position and restart the computer while stating you will see cmos reset press F1 to continue or press DEL to enter bios press DEL and enter the correct time as clearing the cmos the time will be set defult if you cant see cmos jumper pin remove the cmos battery and restrt the computer then shut down the computer and place back the cmos battery in its compartment doing this please remove the power to your hard disk or your haRD DISK MAY GET CORROUPTED
Oct 24, 2010 | Computers & Internet
my toshiba starts up and and goes to a black sceen with a blue box needing a password what kind of password is thhis
Bios PASSWORD can be reset by resetting the BIOS. Take unit to a service place like geek squad and ask if they can clear the CMOS. If you are techie enough you can do this yourself. By removinng the CMOS battery for a few minutes (not the main battery) it is a button type cell.
Jul 18, 2009 | Toshiba Satellite L305D-S5895 Notebook
204 people viewed this tip
David Payne
David Payne
