Tip & How-To about Canon EOS 500D / Digital Rebel T1i Digital Camera
Manual Aperture Video For Canon Eos Rebel 500D T1i
Unfortunately the Canon T1i shoots video in full automatic mode. This means that if you want to change the depth of field...well, you can't. There are many angry T1i owners trying to get Canon to release a firmware update to have it perform like the T2i, but so far that has been fruitless.
So what can a budding videographer do get some artsy-looking footage with his or her T1i? The Band-Aid solution involves fooling the camera into thinking there is a manual lens attached so that the camera will relinquish control. To do this, the communication between the camera and lens has to be severed (don't worry - it doesn't involve modifying anything).
Step 1.
Put the camera into Av or Manual mode.
Step 2.
Select the desired aperture (if the aperture is "wide open" - e.g. F1.8 on the 50mm F1.8 II lens, then skip Step 3).
Step 3.
Press the depth of field preview button on the side of the camera (above the T1i or 500D logo on the curved part of the camera body).
Step 4.
With the DOF preview button still depressed, push the button as if to remove the lens, and turn it very slightly until "F00" shows up on the back display. You may now release the buttons.
Step 5.
Switch the camera to video mode. There will be a warning message, but just do as it says and shoot anyway.
You're now ready shoot some nice shallow DOF shots. Use the manual focus ring on your lens to shift the shallow depth of field around in your shot. Please note that since the camera is no longer communicating with the lens, autofocus will not be available to you. Put the lens in manual mode on the barrel to be safe - many lenses do NOT have manual override and forcing the focus ring while in AF mode can damage the lens.
Good luck and happy film-making!
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
How do I change the F-Stop (Depth of Field) on my black FujiFilm FinePix JX600?
I don't believe that camera allows that. The JX600 is an automatic P&S camera. If you look around, you may find a deal on a Fuji F series camera, which has manual and semi auto controls in addition to full auto.
May 28, 2014 | FUJIFILM FinePix JX600 14 Megapixel...
shutter speed
Like most point&shoot cameras, the A3100 does not give you direct control over the shutter speed. You're expected to just point the camera and shoot, without worrying about such niggling details.
You can gain some control over the shutter speed by changing the scene mode. For example, portrait mode attempts to reduce the depth of field by opening the aperture, which results in a faster shutter speed. Conversely, landscape mode attempts to increase the depth of field by closing the aperture, which results in a slower shutter speed.
Dec 20, 2013 | Canon PowerShot A3100 IS Digital Camera
set aperture
Unfortunately, as with most point&shoot cameras, you don't get much control over the aperture. The camera is intended for you to point and shoot, without bothering about such details.
You can get some control by changing the shooting mode. For example, the Landscape mode will attempt to close down the aperture in order to deepen the depth of field, while the Portrait mode attempts to open up the aperture to narrow the depth of field.
This is one of the things that separate point&shoot cameras from more sophisticated (and more expensive) cameras.
Sep 22, 2013 | HP Photosmart M547 Digital Camera
i have a canon rebel t1i and my view is only optional through the viewfinder for certain modes, not on the display screen. how do i change this?
Set the shooting mode to a Creative Zone mode. Press the LiveView button (TOP LEFT OF round selector). The LiveView image will appear on the monitor.
More detail see the- "Live View Shooting" chapter in the manual.
Dec 24, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
I have a Canon EOS Rebel T1i and am trying to set the ISO and White Balance while in the Full Auto Mode, but can't view the settings on the LCD screen. What am I doing wrong?
Nothing, in full auto mode you can't adjust allmoust anything. If you want to "play" with adjusting some elements you simply need to use some other camera setting other than full auto more. Full auto is simply "point and shoot" for people witch dont know allmoust anything about photography.
Nov 27, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
2,677 people viewed this tip
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
