Tip & How-To about Computers & Internet
How to fix the problem with Belkin Next generation Routers ?
How to fix the various issues with Belkin Basic, Surf, Share, Play, PlayMax Routers ?
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
On the left side below the "utilities" select firmware update and check the current firmware version of your router.
In these updated firmwares all the problems related to various issues have been fixed.
download the latest firmware and update it.
After updating the firmware click on restore factory defaults found below the "utilities" and restore it.
then configure your router according to your internet service provider...
For Cable ISPs click here...
For embarq and centurylink ISPs click here...
For DSL & Satellite ISPs click here....
To configure the wireless part except for play & playmax click here...
Computers & Internet Logo
I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the original passcode key? how do I fix this problem
This is how you reset your router.....
Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    Is there any case that the port from belkin router
    This may happen due to double NAT issue.... the DSL modem might give an IP address in the range of belkin route....that is 192.168.2.X check for the ip address when the computer is directly connected to the DSL modem... now check for the IP adress when the Belkin alone is connected to the computer.... if they both give an IP adress like this 192.168.2.X......(X can be any value) then you will face the above issue..... in that case you can login to router and change the IP address of belkin router from 192.168.2.X to 192.168.15.X this will resolve the issue
    Apr 15, 2010 | Belkin (F5D7230-4) Router (587009)
    Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable. Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable. Open internet explorer / Firefox or any of your default web browser. In the address bar type the default gateway address of Belkin router 192.168.2.1 Belkin router setup page (RSP) will be displayed. Login to the page. (password: leave it blank and click submit) On the left side below the "utilities" select firmware update and check the current firmware version of your router. For belkin basic (F7D1301) router the latest firmware is ver.1.00.16 to download the latest firmware for basic router click here... For belkin surf (F7D2301) router (older firmware ver.1.00.10) the latest firmware is ver.1.00.15 to download the latest firmware for surf router click here... For belkin share (F7D3302) router (older firmware ver.1.00.13) the latest firmware is ver.1.00.18 to download the latest firmware for share router click here... For belkin play (F7D4302) router (older firmware ver.1.00.14) the latest firmware is ver.1.00.20 to download the latest firmware for play router click here... For belkin playmax (F7D4301) router (older firmware ver.1.00.15) the latest firmware is ver.1.00.21 to download the latest firmware for playmax router click here... In these updated firmwares all the problems related to various issues have been fixed. download the latest firmware and update it. After updating the firmware click on restore factory defaults found below the "utilities" and restore it. then configure your router according to your internet service provider... For Cable ISPs click here... For embarq and centurylink ISPs click here... For DSL & Satellite ISPs click here.... To configure the wireless part except for play & playmax click here...
    Jul 24, 2010 | Audio Players & Recorders
    1,835 people viewed this tip
    David Payne
    David Payne
