Tip & How-To about Audio Players & Recorders
Connect the DSL Modem to Router in the port named Modem (usually yellow in color
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
On the left side below the "utilities" select firmware update and check the current firmware version of your router.
In these updated firmwares all the problems related to various issues have been fixed.
download the latest firmware and update it.
After updating the firmware click on restore factory defaults found below the "utilities" and restore it.
then configure your router according to your internet service provider...
For Cable ISPs click here...
For embarq and centurylink ISPs click here...
For DSL & Satellite ISPs click here....
To configure the wireless part except for play & playmax click here...
how do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
how do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
How to install a linksys router to my desk top for my wireless laptop
1. plug in the router
2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
3. connect the router to your computers ehternet port with a second piece of ethernet cable
you can use catagory 5 ethernet cable , or catagory 6
Most linksys routers have 4 to 5 ethernet ports to connect computers to.
One of the ports will be marked as the one to connect to your DSL or Cable Modem
Usually when looking at the back of the router the WAN port will be located to the far left.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
1,723 people viewed this tip
 Grubhead
Grubhead
