Tip & How-To about Computers & Internet
Tips and Tricks for computer issues
Check out my blog at http://techrxgb.com where I post helpful information on your computer.
Computers & Internet Logo
my Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light is on, sometimes i can see a very very dark dim display but currently i cannot use it as its too dim...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
Hanns-G HC194 monitor, no screen, led is flashing in green
hello,
The green flashing power led is a standard symptom of a failure in the power supply board. We have an article about how to repair this unit posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-a-hanns-g-hc194d-with-flashing-power-light/ If you can solder then you should be able to do the repair yourself, if you don't want to do the repair we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 27, 2010 | Computers & Internet
screen is black, audio works fine
This usually indicates a failure in the backlight power supply. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ that explains what goes out and what will need to be replaced to complete the repair. You can also post a few pictures of the power boards to our forum section at: http://www.ccl-la.com/forum/index.php Our techs will then contact you about the parts that have failed. If you don't want to do the repair yourself we do offer a repair service, that information can be found here:http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Samsung T220HD LCD Monitor
blue light flashing
The flashing power light indicates a failure in the power supply. The repair is easy if you can solder. Check out this article on our web site about what needs to be replaced, http://www.ccl-la.com/blog/index.php/capacitors/ If you would like to take a few pictures of your power board and post them on our forum, we can mark the parts for you to replace, that section is at:
http://www.ccl-la.com/forum/index.php If you need parts then contact us thru our web site for a parts quote. If you don't want to do the repair yourself we do offer a repair service, use this link to request service -
CCL_Tech
Corporate Computer
www.ccl-la.com
Feb 28, 2010 | AOC Monitor
I have a samsung 2053bw monitor that does not leave stand by mode. The monitors power light only blinks. I plugged in a different dell monitor and it seems to work fine.
Power supply should be checked out for bad caps with bulging tops/seals first, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 08, 2010 | Computers & Internet
130 people viewed this tip
David Payne
David Payne
