Tip & How-To about Washing Machines
GREEN LIFE
Whenever using the dryer for your laundry ensure
1. You have opened a window when using the dryer.
2. A closed up laundry gets very humid and that humid air gets sucked back into the dryer.
3. The humid air reduces the dryer's effectiveness.
4. Also in case your dryer has an exhaust leading to outside - ensure it is cleaned at least once a month.
Let's contribute to GREEN ENVIRONMENT - GREEN LIFE.
Washing Machines Logo
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
taking a long to time to dry doesn.t get very hot
Igreat answer above now here is a great video shows how it works and what to check
Jan 04, 2011 | Dryers
sewer gas smell
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Apr 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water gathers in dryer when off
Check that the dampener in the vent deflector on the outside of the building to ensure it is closing when the dryer is not in use.
Please take the time to give this solution a fix ya rating
clarkco
Feb 20, 2009 | Maytag MED5800TW Electric Dryer
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
151 people viewed this tip
Top Washing Machines Experts
