Tip & How-To about Computers & Internet
How to convert video to iTunes
ITunes is a proprietary digital media player application, used for playing and organizing digital music and video files. The application is also an interface to manage the contents on Apple's popular iPod and other digital media players such as the iPhone and iPad. But iTunes can not play all video formats, so you need to convert your favourite Video to iTunesplayable formats
Free download Video Converter and install on your computer.
Step 1: Select your video files you want to converted
To select a video you would like to convert hit the Browse... button next to the Input File Name field.
Step 2: Set Video to iTunes Parametres
In the main interface, select To MP4 Menu that iTunes playable format, If you want to change some default settings, you can click "Edit Profile" button to open the pfofile editor window, you can set video and audio codes options, the output video effect will be decided to this settings.
After finishing all the settings, click "OK" button to back the main interface, in Output File Name area, click "Browse" button to select a location to save the output video.
Step 3: Start to Convert Video to iTunes
After you have set up all the conversion parameters, hit the Convert Now! button to start converting Video to iTunes. You can visually judge the conversion process if you hit the Advanced>> button.
Now you can enjoy your video, just drag your converted video to your iTunes. This Video to iTunes is very powerful, it can convert any popular video to other format or other device, Don't miss the opportunity! Come on to have a try!
Computers & Internet Logo
I got a GoGear RaGa 4GB MP3 player recently and have just purchased a song from itunes. How do I get it from my computer to the MP3 player
Apple (and thus iTunes) uses a proprietary format (AAC format, not MP3) and iTunes is designed specifically to work with iPods and other Apple products.
This being said, my guess is that either your GoGear is not compatible with AAC format that you downloaded from iTunes, OR if it IS compatible with the format, it could be that iTunes does not recognize it as a device.
Either way, I would use another music library application (Windows Media Player, MediaMonkey, WinAmp, Amarok, or Songbird, to name a few) One of these may be better at recognizing your GoGear player than iTunes.
Then, if your GoGear does not support the AAC format from the iTunes store, you will want to use a converter to create an MP3 file (you can do this from inside the iTunes application, or get some thing like a media converter found here: http://sourceforge.net/projects/bonkenc/)
You could use these to convert the files to MP3 and then you should be able to transfer them to your player.
Because of the incompatibility and proprietary nature of Apple, you may want to avoid iTunes unless you have an iPod
Mar 08, 2011 | Philips Audio Players & Recorders
I CANT DOWNLOAD ITUNES
ITunes is a free digital media player application for playing and organizing digital music and video files. OS requirements for iTunes:OS:WinXP/2003/Vista/7 compatible_win7.gif
  • Minimum requirements:Windows XP SP2
There are some security features in Internet Explorer that you should know about. Read the following instructions to learn more about how to download iTunes. For Downloading Software Here are the steps
  1. When you download new software (including iTunes and iPod software), a new information bar appears near the top of the Internet Explorer window.
  2. Click this information bar and select Download the File in your system and make sure that..ht1875_02.jpg
  3. A File Download window will appears like this dialog box:ht1875_03.jpg
  4. Click Save, and choose where you want to save the file.
And for optional try this website link for free download,
All the Best!
Sep 06, 2010 | Computers & Internet
i downloaded songs onto my mp3 but they wont play
Here is the info from Sony:
Is it possible to drag and drop music from the Apple® iTunes® software to the portable player using the Content Transfer Application? Solution
sp.gif sp.gif Yes, if you have iTunes software installed, you can transfer music and playlists from iTunes software to the Walkman® player by dragging and then dropping the files to the Content Transfer application.
NOTES:
  • The Content Transfer application supports data transfer from iTunes software 7.6 or 7.7 to the Walkman player.
  • The Content Transfer application supports data transfer from iTunes software 8.0. However, for playlist transfer from iTunes software 8.0 to the Walkman player, make sure you are using the latest version of the Content Transfer application. The latest version can be downloaded from the Sony Support Web Site at http://esupport.sony.com
  • Digital Rights Management (DRM) copyright-protected files are not supported. iTunes music files may be able to be upgraded to iTunes Plus music files, which do not contain DRM.
  • Do not disconnect the USB connection during data transfer.
  • If there is insufficient free space on the portable player, the data cannot be transferred.
  • The Content Transfer application is included with most newer Walkman Video players. It also is available for additional models in the NWZ-A, NWZ-E, and NWZ-S series. Some models may require an update to be compatible. Additional model-specific information can be found in the Drivers & Software section of the Sony Support Web Site at http://esupport.sony.com.
Jan 26, 2009 | Sony NWZ-E436F MP3 Player
How to download songs to the MP3 player
iTunes is an application that allows the user to manage audio and video on a personal computer, acting as a front end for Apple's QuickTime media player. Officially, using iTunes is required in order to manage the audio of an Apple iPod portable audio player, although alternative software does exist. Users can organize their music into playlists within one or more libraries, edit file information, record Compact Discs, copy files to a digital audio player, purchase music and videos through its built-in music store, download free podcasts, back up songs onto a CD or DVD, run a visualizer to display graphical effects in time to the music, and encode music into a number of different audio formats.
You have to download iTunes software and make a playlist then sinc the ipod.
Dec 23, 2008 | 2007 Alfa Romeo Spider
254 people viewed this tip
David Payne
David Payne
