Tip & How-To about Computers & Internet
How to Reset, Remove and Unlock Windows Login Password
It has happened at least once to most of us - we reinstall Windows, or add a new user, or just get distracted with other things. And then when we want to log on and we suddenly notice that we don't remember our Windows password anymore! So what can you do to bypass a lost Windows administrator password?
Reset Windows Password is a Windows password reset boot CD that enables you to easily reset lost administrator or user passwords for Windows 7, XP, Vista, NT, 2000, 2003 and 2008. It will come in handy when you are unable to log into Windows due to a forgotten or unknown passwords.
How to Reset, Remove and Unlock Windows Password:
  1. Insert the newly burned CD/DVD to your locked computer, then reboot your computer.
  2. Then you will see Reset Windows Password is initializing.
  3. Simply select your Windows installation if multiple operating systems have been installed on the computer, the program will list all user accounts for your selected Windows installation. Select a user account from the list, then click the "Reset" button to reset the password.
  4. Click the "Restart" button to reboot the computer. Now you are able to log into Windows without a password.
It's that easy!
Computers & Internet Logo
forgot administer password
Which password? Bios? Windows? Linux? Mac?
May 11, 2015 | Acer Aspire m5640 PC Desktop
safe mode windows
if you didn't set the default administrator password, then you should
have been able to pass. However, if you remember that password, then please typed it in. Else you either need to download a third-party software that does the job, or you do the following instead.
Restart the PC, hold down F8 once you enter the Windows Boot Menu choose Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds that user to the Administrators group and the third command removes the user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at a Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Sep 27, 2013 | Dell Latitude D830 Notebook
brand new lexmark printer, toner and cartridges installed, but get error 32 unsupported black cartridge error -tried updating drivers on lexmark site -tried taking cartridge out and reinstaling it -problem occurs as soon as printer is warmed up - unable to print
You could find the root cause by performing different steps. One of the easiest methods is that you need to make sure that the plastic protective tape which is usually used on the new black cartridge is off. Usually the user makes this mistake. This mistake might occurs due to absent-mindedness. The reason could also be some distractions which happen while loading the new black ink cartridge.
Nov 17, 2010 | Lexmark C546DTN COLOR LASER PRINTER ...
Sync iphone calendar with outlook 2003
hello!
try the ff:
Reset Sync History
- Open iTunes
- On the Edit menu, click Preferences.
- Click the Syncing tab.
- Click the Reset Sync History button.
disable third-party add-ins
- Open Outlook 2003
- From the Tools menu, choose Options.
- Click the Other tab.
- Click the Advanced Options button.
- Click the COM Add-Ins button.
- Determine whether any third-party (non-Apple) add-ins are present in this list. The add-in "iTunes Outlook add-in" is made by Apple and can be left alone.
- Deselect the checkbox for each third-party add-in in this list.
- Click OK.
Reinstall the iTunes software
Attempt to sync content in a new Windows user
- From the Start menu, choose Control Panel.
- Open User Accounts.
- Select Create a new account and follow the instructions to complete the account setup process.
Note: Make sure you only use standard ASCII characters for the new user name.
- Once the new account is created, choose Log Off from the Start menu.
- Log into the newly created user account.
Once you are logged into the new user account, create a few test contacts and/or calendar events in your compatible application of choice and attempt to sync that data to your iPhone.
May 08, 2008 | Apple iPhone Smartphone
178 people viewed this tip
David Payne
David Payne
