Tip & How-To about Computers & Internet
Ways to save your laptop from greif without its own fluids
First never eat aroun your laptop, but when you do make sure you dust it for crumbs later. this involves turning it off and using a vacuum, canned air, and making sure that the fingernails you clipped are not causing any keys to stick. now dont even get me started on soda! but these should never be:
A. close enough so that when they tip over they can spill or land or river flow next to the computer. Nor B using the cold sweat from the outside of the glass or moring dew that can short or even get wet a USB key that will indeed corode. No it wont do it on the spot nor will it do it in a week. but you will continue to transfer that moisture around until some where some time it will short it or damage it. its not worth the head ache. put drinks on the floor do not trust a straw. and refillable bottles do sweat, andwash your keyboard and hands often. if using an antibacterial on the keyboard test it o one of the keys you dont need or use often as some can and will take the key paint with them. if they do no fear you can replace the key for about 6 bucks normally with shiping.
Computers & Internet Logo
the cooling fan isnt quiet
computer needs servicing processor over heating
May 03, 2014 | Acer Aspire 5600U all-in-one desktop
only one speaker working in hp dm1
This could ba a hardware problem with the power connections or dust
Laptop speakers often suffer the consequences when you snack while using the laptop, usually while surfing the Web.
Small particles of chips, crackers and other sources of crumbs easily fall into the little holes of your laptop's speakers, therefore causing sound distortion.
This sound distortion problem can be fixed by cleaning out your laptop's speakers with a safe process that does not require any dismantling of the laptop.
Turn the laptop off, unplug the power cord and remove the battery to lower the risk of damage to the computer and electric shock.
Wipe away any exterior debris using a cotton swab.
Dip the cotton swab in rubbing alcohol and swab away to remove any sticky residue.
Rubbing alcohol dries quickly, making it ideal for cleaning electronics.
Use a hand-held vacuum with the brush attachment to vacuum out any debris in the speakers.
A full-sized vacuum may be too powerful and can damage the speakers.
Reinstall the battery, plug the computer back into the electrical outlet and start it up.
hope this helps
Oct 17, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
PLEASE, I HIBERNATED MY LAPTOP AND AN HOUR LATER I POWERED IT, THE SCREEN WAS BLANK WITH ONLY THE POWER LED LIGHT BLINKING. THERE IS NO SIGN OF IT BOOTING. PLEASE I AM CONFUSED AND NEED HELP. I AM SUSPECTING THE PROBLEM CONCERNS THE SECURITY LOCK SLOT BUT I'M NOT SURE. PLEASE WHAT CAN I DO?
Try turning it back on without the batter in it.
How dusty is the area by the fans. If your laptop is filled with dust, it will overheat...which can be a source of the problem. If so, take a vacuum and connect it to the fan. Use your judgment on how close to get the vacuum to the fan (i.e. don't use a 7hp shop vac or you'll remove more more than just dust.)
If you have access to another monitor, try connecting it to the laptop.
Dec 12, 2009 | Computers & Internet
Some keys on my keyboard keep sticking
hi Linda - keys stick over time because dust, crumbs, etc. get under them and cause them to stick.
Many times you can just repeatedly hit the sticking key a dozen or so times and restore it to its original status. Actually what u r doing is pulverizing the dust or crumbs into micro pieces..
Also try carefully tipping the open laptop upside down on a piece of newspaper or bed sheet and tapping it as if u were burping a baby.
Try these things and let me know. If I don't hear back cause it is resolved, kindly score my answer as a fix ya! thanks.
Feb 27, 2009 | Toshiba Tecra A8-S8314 Notebook
143 people viewed this tip
David Payne
David Payne
