Tip & How-To about Computers & Internet
Suddenly the computer no display and turn off itself.
If someone is doing important work with a computer problem that may cause anger or frustration on the problem computer.
In case this situation happened to you? What should you do?
If you do not know any other way of transporting your computer to a computer repair center.
Here I want to give some tips before you bring your computer to a computer repair center.
1> Take care of your emotions, your anger is not due to further increase the pain on your computer:)
2> close and remove the main source of electrical power to the computer.
3> Remove the cap of your computer casing.
4> Unplug your computer's ram.
5> Sweep ram slot with a small brush or paint brush that has not been used (new)
6> After cleaning the ram slot, use a rubber eraser to clean the copper surface on your ram.
7> when you're done, install the ram in the slot.
(If you have a ram that is for sure good or new ram, I suggest you make troubleshooting with the new ram is better)
8> reinstall the electrical power source on your computer and then press the button to switch on your computer.
9> If your computer can be activated in normal, scan your computer with antivirus or for ordinary maintenance, such as scan disk or disk defragment.
Problems if your computer is not available on the former. This requires you to perform more detailed troubleshooting process again.
First of all, you need to provide extensive troubleshooting hardware to do this work. If you are skilled to do this work and have access to the supply of materials to make this work,
I think it is not a problem for you,
But do not worry ...even if you do not have extensive knowledge in computer repair, with Fixya.com will help and guidance extended to solve your computer problems ..so only at the moment
thanks fixya
===>Give rating if this helped solve your problems<===
Computers & Internet Logo
I think I have anger/controlling issues mainly towards people I love the most etc family members partner . How can I deal with them it's so hard I try but it's not good enough
talk with an anger management counsellor
you have acknowledged the problem now take the next step and talk it out
maybe your expectations are too high and it is frustration that is leading to anger
What ever--- talking to professionals is the best way to go.
Feb 21, 2015 | Cars & Trucks
windows failed coz of critical system driver is missing or corrupt.. volsnap.sys status 0xc0000098
That can be frustrating :( hope my solution below helps..
based on the current situation, I suggest trying the following steps: restart the computer and keep pressing F8; Use Last Known Good Configuration.
If the issue still occurs after that, I suggest testing if we can boot from a Windows disk. If so, please install Windows on another partition and access your important data. After backing up those data, you can use Windows disk to format the drive and reinstall Windows.
However, if we cannot boot from a Windows disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
May 26, 2011 | Computers & Internet
Myexternal hard drive wont boot and it says its unreadable or corrupted. maxtor 500gb tried a lot to resolve proble what exactly now i cant remember
You need to include info about your computer, and which format your external hard drive is: USB or Firewire. Are you using a Mac or PC?
"Boot" refers to the situation in which your hard drives sets up the operating system of your computer. I doubt this is the case. Do you mean that your host computer does not recognize the external drive?
If the latter is true, this can have many causes.
Also, did this drive work at some time? If so, with this computer, or a different one? The problem may be as simple as installing the proper driver, or at worst, the drive may be non-functional.
Most manufacturers of mass produced external drives, in the interests of being competitive, use drives that are not as durable as you would expect in a backup drive. Also, the interface in the case that houses the external drive often fails, so the drive itself may be OK. You can check this, but observe the following conditions:
1. You will void the warranty if you open the external drive case.
2, The warranty will replace the drive, but will not recover the data on that drive.
3. You can remove the external drive from the case and install it in your host computer to check it, if your computer is compatible with that drive. You need to know how to set the jumpers of that drive for your setup.
4. This can be a difficult and frustrating process. If the data on the drive is important enough, you have to decide if the cost to retrieve it is worth it to you.
Contact me if you need more info.
Oct 28, 2010 | Maxtor Hard Drive
how do I put batteries in a gardner bender circuit alert voltage sensor
On my GDT 3200 you had to pry and force the black padded case off of it. There is no instructions how to put the batteries in, and I nearly broke the meter taking off the case. Just try to force that case off of there. Hand strength combined with frustration and anger will help in that step. Once the black armored case is off, it's self explanatory. There's two screws on the back that come out and the red unit splits in two. Install the batteries and put it back together.
Sep 14, 2010 | Actron Digital Multimeter Tester
235 people viewed this tip
David Payne
David Payne
