Tip & How-To about Computers & Internet
How to expand the lifespan of your projector lamp
One of the most frequent problems encountered is people replacing the bulbs with their bare hands. While this is fine for an ordinary light bulb, it is not a good practice for a projector lamp. The lamp in a projection unit burns much hotter than any regular light bulbs. The effects of touching it with bare skin are equally magnified and problematic.
Touching a projector bulb with the bare skin leaves traces of oil on the lamp surface. While this may seem a very minor detail, it is detrimental both to the bulb and the quality of the resulting multimedia display. The oils will get burnt onto the lamp and drastically reduce the lifespan. As the oil is baked into the surface, it actually diffuses the light being projected, reducing the lumens actually being sent to the refractive surfaces. The light will not be enough to project the image that has come to be expected from the home theater projection system. While the problem may not be noticeable at first, over the course of a little time, the quality will degrade to the point of not being viewable.
Turn off the projector power after turning off the lamp
It is highly recommended to turn the power on the projector to the "off" position only after having turned off the lamp and allowing it to cool. This will allow the cooling fans to do the job they were designed to do. While rapid cooling and heating result in repeated contractions and expansions of the bulb filament, it is much better that it be done more quickly with the cooling fans. Likewise, turning the projector on and allowing the cooling fans to run for a moment before turning on the lamp will help as well. This will add hours to bulb life expectancy and allow for longer hours of viewing pleasure on the home theater projection system.
Constant Movements
Constantly bumping or moving the projector, especially while it is hot can be very detrimental to the projector lamp. The filament in the bulb loses almost all tensile strength when it is heated during normal usage. It is much the same as the filament in a camp lantern. The principle is the same; the filament effectively becomes almost the same consistency as ash, making it extremely vulnerable to damage when it is hot. Even after proper cooling, the lamp filament is very sensitive. Care should be taken when moving the projector for whatever reason. While it is always a good idea to be careful with electronic equipment, some aspects of the home projector are actually a bit more sensitive.
It will usually be necessary to move the projector when cleaning the filters. As always, it is a good idea to move it carefully without jerking it around or bumping it any more than needed. Taking an extra moment or two to check the projector mount and make sure it is still securely fastened can also be beneficial and prevent slips and movement which may otherwise be harmful.
With a little care and a little preventative maintenance, the projector lamps will still need to be changed, but not nearly as often.
Computers & Internet Logo
headlight not working
TRY ANOTHER LIGHT BULB.BUT DONT LET BARE HANDS TOUCH BULBS BECAUSETHEY ARE HALOGEN.OILS FROM YOUR FINGERS OR HAND WILL CAUSE THE BULB OVER HEAT AND BLOW.IF YOU TRY ANOTHER BULB AND STILL DONT PROBLEM COLUD BE BULB SOCKET CORRODED OR DAMAGE OR WORN BULB CONTACTS.LOOSE POOR GROUND WIRE OR SHORT IN WIRES TO BULB SOCKET.
Jul 12, 2010 | 2005 Chevrolet Impala
LED does'nt work on tail light but conventional bulb is working
Maybe your LED bulb is defective and so you need to replace that LED bulb with a new good quality one.
I can recommend you search for a LED High Bay Lights which are of high quality and cost-effective.These bulbs are reliable and save a lot of power.
You can also find here simple and easy to use plug and play LED lamps.
Hope this will help!
Apr 11, 2017 | 1995 Honda Civic
how to replace a front light bulb on 2001 stratus
REACH BEHIND HEAD LIGHT ASSEMBLY.ROTATE THE SEALING COVER COUNTERCLOCKWISE TO REMOVE IT FROM THE HEAD LIGHT HOUSING.REMOVE THE BULB LOCKING SPRING. DISCONNECT THE BULB ELECTRICAL CONNECTOR.PULL STRAIGHT OUT ON THE BULB TO REMOVE IT.BY BULBS BEING HALOGEN.DONT TOUCH WITH BARE HANDS. OIL FROM HANDS WILL CAUSE BULB TO BLOW BY OVERHEATING.HANDLE BULBS WITH CLEAN GLOVES OR NEW CLOTH GLOVES.
Oct 31, 2009 | 2002 Dodge Stratus
LOW BEAM HEADLIGHTS DON'T WORK FUSES ARE GOOD AND LIGHTS KEEP BLOWING OUT --HIGH BEAM LIGHTS,FOG LIGHTS,AND CRIUSE CONTROL ALL WORK FINE.HOW DO I FIX THIS PROBLEM.
If you are handling the bulbs with your bare hands that is why your bulbs keep blowing out. use a washcloth to put the bulb in or rubber gloves, anything that will keep your hands from touching the bulb.
Oct 05, 2009 | 2003 GMC Envoy
bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
2,224 people viewed this tip
David Payne
David Payne
