Tip & How-To about Cycling
Bajaj XCD 135 vs honda twister
I had XCD 5 days ago i had sold it, this is just a rubish bike from bajaj auto's. this is getting heat after 3 to 5 Km.... and then it use to drive hard, this is just like it seem to end of fuel, i visited many time but they have no any solution and after 13 month i sold it, to i have honda Twister cb this is realy 100 time better than XCD 135 couse i use its my persnol expiriance any other enquary call me 09888447047
Cycling Logo
i have bajaj XCD 125, i have changed the new piston & cliche plate but bike engine is vibrate and after 2 KM engine automatic off, please suggest me what i do best my bike.
Hi, Anonymous and the usual suspects are:
1. Wheels and/or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect/poorly tuned engine.
7. Internal engine problem/flywheels shift.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.youtube.com/watch?v=94riWeTa6Io
Scooter rear wheel vibration problem
Bajaj XCD 125 DTS Si 2008 service manual DOWNLOAD FREE FULLMANUALS COM
Manual Bajaj 125 XCD
Manual Kawasaki Bajaj Wind 125 Documents
Jun 10, 2012 | 2008 Bajaj XCD 125 DTS Si
I have a Baja mini bike 5.5 red. I just got a brand new carb and its the right one but I go into a little prob that I don't know what to do with. The bike will only start when I put gas in the air filter but when it starts it excelerates and idk what to do I replaced a throttle and it still has that problem. I'm guessing that the clutch is wrong. Please help thanks
Hi, Trlerkiller1 and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
Top results matching 2009 Bajaj XCD 125 DTSSi Scribd
Apr 15, 2012 | 2009 Bajaj XCD 125 DTSSi
i want electrical control wiring diagram of bajajXCD 125cc bike
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Bajaj XCD 125 DTS Si 2009 service manual DOWNLOAD FREE FULLMANUALS COM
Apr 15, 2012 | Bajaj Discover Motorcycles
bajaj xcd 125 service manual
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Bajaj XCD 125 Bike Prices Reviews Photos Mileage Features Specifications
Bajaj XCD 125 DTS Si specifications features colours mileage reviews...
Feb 03, 2012 | 2008 Bajaj XCD 125 DTS Si
243 people viewed this tip
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
