Tip & How-To about Computers & Internet
How remove Apple Macbook a1181 Battery
First you need to flip over your computer, then put a coin in the slot next to your battery, then turn it to the UNLOCK possistion and the battery will come right out.
Computers & Internet Logo
i locked my computer and i forgot the password
Assuming you mean the 'BIOS Password', turn off & UNPLUG the power cable. Then open the case, find the little silver battery 'coin cell' battery (type CR2032) = on the moherboard, make a note which way round it is & and remove it for a coiple of miniutes.
After putting it back in, when you next power up, you will have to eneter the current time & date into the BIOS..
Nov 12, 2012 | E-Machines eMachines Desktop PC
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
136 people viewed this tip
David Payne
David Payne
