Tip & How-To about Computers & Internet
Removing write protection
In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from http://www.troublefixers.com/wp-content/uploads/Miscellaneous/add.bat, and double click after download the key will be automatically added to registry.
You will get the box like this
3. Double click the key WriteProtect in the right panel and set the value to 0 in the Value Data Box and press OK button.
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Thanx
Computers & Internet Logo
how to remove write-protection
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Sep 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
how can i remove write protected from my kingstone memory stick
change value to 0 and press enter
good luck
Aug 20, 2011 | Kingston Technologies 512MB DataTraveler I...
its write protection its not working what is the solution
The problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
Jan 11, 2011 | Transcend (589307) Media
I JUST BROUGHT A NEW PEN DRIVE. FIRST TIME USING IT, AND THE PROBLEM ALREADY HAPPEN. IT IS WRITE PROTECTED. I ALREADY DONE EVERY POSSIBLE WAY TO GET RID THAT WRITE PROTECTED., BUT IT DIDN'T SUCCESS.. I TRIED TO CHANGE MY REGEDIT(WRITE PROTECTED TO 0 VALUE), EVEN INSTALL SMART REMOVER AND OPEN CMD TO FORMAT MY PEN DRIVE...
Jan 11, 2011 | Kingston Combo 4GB DTI USB and 4GB...
write protected
Jan 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
9,725 people viewed this tip
David Payne
David Payne
