Tip & How-To about Cell Phones
Import MOD to FCP ? How to import MOD to Final Cut Pro to edit your MOD files
Final Cut Pro is a very sophisticated video editing program made by Apple and provides professional editing of any QuickTime compatible video format including DV, HDV, P2 MXF (DVCProHD), XDCAM, QuickTime MOV, QuickTime MP4 etc. It has become the choice for multimedia journalists using Apple computers and many Hollywood film makers.
However, Final Cut Pro does not support MOD files, which poses a problem if you are using JVC, Panasonic or Canon camcorders that take MOD videos. So if you want to edit MOD in Final Cut Pro, you will need to convert MOD to Final Cut Pro supported formats.
Doremisoft Mac MOD converter provides the perfect solution to letting you import MOD to FCP by converting MOD to Final Cut Pro supported formats.
The four steps below will guide you to import MOD to Final Cut Pro:
Step 1: Add MOD files
Click the "Add File" button to add the MOD files you want to import to Final Cut Pro from your Mac hard disc. Then double click a file or select a file and click on "Open" to add it.
Step 2: Select the output format
Click the small arrow at the end of the Profile field, and you will see the Profile drop-up list. Move your mouse cursor to "HD Video" and click on the "HD MOV" profile. This option will let you convert MOD to FCP MOV. Then you can tick the "Apply to all" option that will convert all added MOD files into selected Final Cut Pro supported format. You can also convert MOD to FCP MP4 if it is what you prefer.
Step 3: Start to convert MOD to Final Cut Pro
Find the round Start button on the lower right part of the main interface to start the conversion. On the conversion window you can see the elapsed time and the remaining time. Now you can decide how to kill the time before the conversion is finished. Then just don’t forget to come back for the converted files you want to import to FCP.
Tip: You can also use Doremisoft Mac MOD Converter to do easy editing such as cropping, trimming, and video effects to your MOD files, click here to see how.
Step 4: Import converted MOV to Final Cut Pro
Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Then select one converted file from the Choose a File window and press the "Choose" button to choose this file. Then find the file in the resources list for the project and drag the file into the Timeline and then save the project.
Now you have successfully imported MOD to Final Cut Pro and just start editing!
Cell Phones Logo
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro? Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed. If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac. Tips: Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit. How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro? Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks. Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro? Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up. Step 2:Load Kodak video files First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book. Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter. Step 3:Select the output format and destination Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location. Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location. Step 4:Start the conversion After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion. Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro. Step 1:Import Kodak videos to Final Cut Pro Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project. Step 2:Edit Kodak video in Final Cut Pro Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline: One: Edit video and audio timing There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place. Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other. Two: Add transitions For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions. Three: Export video Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
Sep 17, 2010 | Computers & Internet
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below: Part One: Convert flip to Final Cut Pro video Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro. Step 1: Add flip videos Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter. Step 2: Select a Final Cut Pro supported output format Click the Profile drop-up list and select Step3: Convert flip video to Final Cut Pro Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro. Part Two: Import converted videos to Final Cut Pro Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file. Step 2: Find the file in the resources list for the project. Step 3: Drag the file into the Timeline and then save the project. Part Three: Edit flip video in Final Cut Pro Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline: Step1: Edit video and audio timing There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place. Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other. Step2: Add transitions For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions. Step3: Export video Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save. As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there. You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro. If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
Aug 13, 2010 | Computers & Internet
146 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
