Tip & How-To about Computers & Internet
Shortcut for Task Manager in Windows
To open the Task Manager in Windows -- Press Ctrl + Shift + ESC
(Works in Windows XP, Windows Vista, Windows 7)
Computers & Internet Logo
What three keys are pressed together to open the Windows Task Manager
Windows Vista,Windows 7 & Windows 8, Windows 10, press CTRL+SHIFT+ESC
Jun 29, 2017 | The Computers & Internet
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management Windows key + E = Explorer ALT + Tab = Switch between windows ALT, Space, X = Maximize window CTRL + Shift + Esc = Task Manager Windows key + Break = System properties Windows key + F = Search Windows key + D = Hide/Display all windows CTRL + C = copy CTRL + X = cut CTRL + V = paste Keyboard Shortcuts [Alt] and [Esc] Switch between running applications [Alt] and letter Select menu item by underlined letter [Ctrl] and [Esc] Open Program Menu [Ctrl] and [F4] Close active document or group windows (does not work with some applications) [Alt] and [F4] Quit active application or close current window Ctrl] Lft., Rt. arrow Move cursor forward or back one word Ctrl] Up, Down arrow Move cursor forward or back one paragraph [F1] Open Help for active application Windows+M Minimize all open windows Shift+Windows+M Undo minimize all open windows Windows+F1 Open Windows Help Windows+Tab Cycle through the Taskbar buttons Windows+Break Open the System Properties dialog box explorer shortcuts END....... Display the bottom of the active window. HOME....... Display the top of the active window. Type the following commands in your Run Box (Windows Key + R) or Start Run devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator mspaint = Microsoft Paint wmplayer = Windows Media Player control = Opens the Control Panel Internetbrowser type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it For Windows XP: Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the previous paragraph. CTRL+UP Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Refresh the active window. F5 Cancel the current task. ESC
Oct 12, 2010 | Computers & Internet
HOW RESTART WINDOWS EXEPLORER WHEN IT STOPS WORKING
if everything is empty and no view of dektop try to press ESC+SHIFT+CTRL. In opened window select FILE->NEW TASK. Enter word EXPLORER in textbox and press ENTER.
Aug 12, 2014 | Microsoft Windows 7 Home Premium for PC
The monitor comes on each time but then goes dark after a few seconds
i think u r using window 7 or vista.
this happens when ur system is infected by virus.
so, you may try this trick....
Note:- If you have multiple user accounts or your account is password protected then start from Step-1 else skip Step-1 and Directly follow step-2 instructon
***** Step-1 ****
press ::
ctrl + shift + esc
or
ctrl +alt+ delele
then you will see a screen containing some menu such as "Start Task Manger", "Switch User" etc....
if u have ur account password protected... then select "Switch user"...Enter password and press enter..
if again screen become black,,,
then do step 2
***** Step-2 ****
press ::
ctrl + shift + esc
or
ctrl +alt+ delele
select "Start Task manager". then do this: File>New Task(Run..)
Type this coomand:
explorer.exe
and click Ok.
Now u can back up your important data and files.
Install new windows operating system if Anti virus fails to Detect the virus and fails to repair the system.
Jan 16, 2011 | Gateway HD1900 19" Monitor
186 people viewed this tip
David Payne
David Payne
