Tip & How-To about Health & Beauty
How stop unwanted hair growth on skin?
Usually we remove the hair that we see. This inturn opens up the orifice, and hair follicles, are exposed. When we apply Nohair Lotion ,these are deactivated.
That hair, which we do not see, are present below the skin surface at various stages of growth and do not get removed by usual hair removal methods. Some of the follicles are partially deactivated by initial application of NoHair. Hence, repeated applications are required to get a perceptible effect Though even after first application reduction in the re-growth and frequency of hair removal can be seen.
Effectiveness of NoHair depends of the effective Hair Removal When the hair is plucked/ pulled from the root. It exposes the core of the hair-manufacturing factory to the NoHair. The active principle of the NoHair damages it permanently. Repeated applications of NoHair after every hair removal sessions effectively deactivate more and more hair follicles. As we are all born with a limited number of hair follicles on the body, the number of hair keep declining
Health & Beauty Logo
Are there any possible risks of undergoing hair transplant surgery?
There are no proven risks or side effects associated with hair transplant surgery. Feeling of itching and discomfort is usually experienced for a period of 3 to 4 weeks but these tend to disappear as time. Feeling of pain is also minimal as the surgery is conducted giving local Anastasia. While i underwent hair transplant surgery in Seager hair transplant center in Toronto I was given local Anastasia prior to surgery.
Jan 15, 2014 | Health & Beauty
I am interested in using Rogain for my thinning hair. Can anyone tell me a little bit about how it actually works
Rogaine comes in either liquid or foam. It can take up to 12 weeks for hair follicles to start growing. I had pretty good results with it, but I would just be careful since my brother experienced a lot of redness on his scalp after applying it.
Apr 24, 2013 | Health & Beauty
How does electrolysis actually remove hair? I just dont see how it works.
You plug electrolysis machines into the electricity, and then volts of electricity are channeled through the tweezers , which zaps the hair follicle. Usually that follicle is then destroyed and the hair doesn't regrow.
You have to be really careful to follow the instructions carefully in order to avoid skin burn and other injuries.
Feb 18, 2013 | Health & Beauty
What is Laser Hair Removal?
Laser hair removal is a procedure by which hair is removed from the body by utilizing a long pulse laser. Lasers are developed and designed from years of research. The laser parameters are carefully defined by studying the anatomy of the hair follicle and precisely matching the laser light and pulse duration to the follicle size, depth and location to inhibit the re-growth of the hair.
Laser hair removal is performed by a specially-trained laser specialist or a doctor depending on where you go, who distributes the light of a long pulse laser onto the skin. The laser works by disabling hairs that are in their active growth cycle at the time of treatment. Since other hairs will enter their growth cycle at different times, several treatments are necessary to disable all of the follicles in a given area.
Nov 23, 2010 | Health & Beauty
645 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
