Tip & How-To about Computers & Internet
How resolve cannot "Connect to Network Printer" with Windows Vista
One of the more interesting errors in Windows Vista happens when you try to connect to a shared network printer. Most of the time you'll receive an "Access is Denied" error when trying to connect even though you can see the printer on the network and everything else is working properly.
Everything else on the network appears to work properly, shared files, internet access, etc. However, you just cannot access the ahared printer and print.
The solution is to add the printer as a local printer and then try printing. Follow the directions below to accomplish this.
1. Go into Control Panel 2. Underneath the Hardware and Sound category, click on Printer 3. Click on Add a printer from the top menu 4. Click on Add a Local Printer 5. Choose Create a New Port with type of port remaining Local Port, then click Next 6. In the Port Name box type the path to the printer you wish to connect to and Click Ok
Ex. \\mycomputer\myprinter
If the computer you wish to connect to is named Bob and the printer is called HP then the path would be \\Bob\HP
7. In the Install Printer Driver screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish. 8. You should now see the printer installed in the Printers window. 9. Right-click on the printer and click Properties 10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from Windows Vista to this networked printer without any problems.
Computers & Internet Logo
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked windows 7 computer. I installed cm1312series-win7-full-solutions-am-emea1-v5.1.exe on the windows 7 computer. Windows 7 computer is printing and communicating with printer but cannot scan from printer to computer (from printer) can only scan from computer.
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA With three different versions of Windows being used now, you?ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines. In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version). Set Windows 7 Share Settings On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter. Then click on Change advanced sharing settings? Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles. Depending on your setup, you might want to turn off password protected sharing. Other wise you?ll need to enter the password for each machine in, which isn?t that big of a deal. Turning it off while you?re setting it up makes things a bit easier though by saving a step. Set Vista Share Settings On the Vista machine we need to double check and make sure it?s sharing settings are ready to go. Right-click on Network and choose Properties. The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery. Also on the Vista machine you might want to turn off password protected sharing ? but it?s completely up to you. Share Files Windows 7 View Now that we have the correct Settings On each machine, it?s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC. There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared. Share Files Vista View Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it?s MYSTICGEEK-PC). I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting. Then you?ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available. And you can continue browsing through all available shared folders and files. Printer Sharing As we showed above, you can see the printer connected to Windows 7. Let?s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter. Right-click on the shared printer and select Properties. Under the General tab click on the Print Test Page button. The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine. Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer. Provided everything prints out successfully you might want to make it the default printer. Troubleshooting If your machines aren?t able to see each other or the printer isn?t working?here are a few steps you might want to use to determine where the problem is. Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above. In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer? If the printer isn?t working, double check to make sure you have the latest drivers for each OS installed.
May 24, 2010 | Computers & Internet
No net connectivity
If you encounter difficulties accessing computers that are visible on the network map, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
To set up Network Sharing between XP and Windows Vista, please note that File and Printer Sharing is different in Windows Vista than from the setup in Windows XP.
On a computer running Windows XP, click Start, click Control Panel, and then click Network Connections.
Click Local Area Network Connection, click Properties, and then view the list of items used by the network connection.
Ensure that the Link-Layer Topology Discovery Responder check box is selected.
Jul 02, 2009 | Microsoft Windows Vista Ultimate Edition
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers coundn't connect. Keep getting an error 0x0000000d.
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
477 people viewed this tip
David Payne
David Payne
