Tip & How-To about Cell Phones
How to format your memory card
First take a adaptor and insert the memory card
then connect it with your pc
and right click on it and select format
then the memory card is fresh and u can use it anytime
thank you
Cell Phones Logo
forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
im phon not format/delete
  • Prepare your memory card for formatting. Decide whether you would like to format using your phone or your computer. If you decide to use your computer, remove the micro memory card from your phone and place it into the memory card adaptor. If you decide to use your phone's removable memory card slot, insert the memory card into the phone while the phone is off, before turning on your phone.
  • 2Navigate to the menu and select your phone options. Locate the menu that includes the technical list; you should see "Media Card" or "Memory Card" listed as an option. If your phone has a separate menu for Memory options, look within this for your memory card menu option.
  • 3Access the memory card menu and click "Options." Be sure that memory card support is enabled. Next, select "Format." This may be found listed or you may need to click on the menu within the memory card menu you have already accessed. After selecting the format you may have the option to choose between formatting the media card and/or the device memory. Select "Media card" if confirmation is required. Keep in mind you will be losing any data previously stored on your card.
  • 4Select OK when your phone asks you to confirm format. Your memory card will now be formatting to your phone and a progress bar may appear. Do not power off or navigate away from this screen. When formatting is complete, your phone will notify you and the progress bar will no longer be visible. You may need to confirm with an "OK" that your memory card has finished formatting.
  • 5For Windows users who wish to format using a computer, place the micro memory card within the adaptor and insert it into your computer's memory card slot. You can also connect to your computer using an external adaptor if your laptop doesn't feature one built in. After connecting the memory card, select "My Computer" within your Windows menu. Select your memory card, which should be listed within this folder. Right-click on the menu and select the format. Your computer settings will prompt you to accept the format and complete the process.
  • sincerely. God bless you.
    ernesto cuadra
    managua,nicaragua.
    Dec 17, 2011 | Sony Ericsson Cell Phones
    kingston 2 gb i cant format showing insert a disk and then try again i want format how
    sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at vicky.akon11@gmail.com i will help you again take care
    Mar 26, 2010 | Kingston flash memory card - 256 MB -...
    My memory card does not format. You have any solution please give right now
    Best to use the Camera to reformat the Chip.
    If this fails try your PC select the card Right click then format.
    If this falls you may have a defective chip.
    Hope this tip helps.
    r/
    David
    Feb 20, 2010 | SanDisk Memory Media
    cell phone how do you format the sd card?
    just go memory card in that u find format option
    select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
    Feb 20, 2009 | Nokia Cell Phones
    168 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
