Tip & How-To about Cameras
Guide to import/edit Flip videos in Premiere Pro with several simple steps
Overview of Adobe Premiere and Flip Camcorder: Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc. Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro? Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Why not download Flip Pro to have a try?
Cameras Logo
what is the real purpose of the adobe audition?
Adobe Audition (formerly Cool Edit Pro) is a digital audio workstation from Adobe Systems featuring both a multitrack, non-destructive mix/edit environment and a destructive-approach waveform editing view.
Adobe® Audition® software delivers the professional tools you need to make your video and audio productions sound their best. Handle a wide range of audio production tasks efficiently, including recording, mixing, and sound restoration.
What's new in Adobe Audition
au-native-mac-support-147x83.jpg Native Mac OS support Record, mix, edit, and master your audio with a powerful cross-platform audio toolset: Adobe Audition CS5.5 runs natively on Mac OS X v10.5 and v10.6 as well as Windows®.
au-roundtrip-editing-premiere-147x83.jpg Roundtrip editing with Adobe Premiere Pro Easily sweeten audio for video. Pass individual clips and multitrack mixes from Adobe Premiere® Pro CS5.5 software to Adobe Audition for editing, or send Adobe Premiere Pro sequences with a reference video to Adobe Audition for complete soundtrack creation.
au-project-exchange-147x83.jpg Project exchange with third-party NLEs and DAWs Easily move sessions between Adobe Audition and Avid Pro Tools using built-in OMF import and export functions in Adobe Audition. Share files with other video NLEs via XML interchange.
au-5.1-support-147x83.jpg Native 5.1 multichannel support Edit multichannel files and mix your projects in 5.1 surround. Adobe Audition CS5.5 includes a Surround Panner in the Mixer View, as well as a new Surround Reverb effect and Amplify, a multichannel gain processor.
Aug 17, 2011 | Adobe Computers & Internet
408 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
