Tip & How-To about Computers & Internet
Speeding Up Your Computer (Windows XP)
Note: these instructions are for Windows XP, however the procedure is very similar for both Vista and 7.
1. Limit the number of programs booting with your computer.
To do this click on the "Start" button, then choose "Run..." Type in msconfig then press enter. A new window will open called the "System Configuration Utility". Click on the "Startup" tab.
All of the programs that have a check in their box are set to boot with your computer. If you recognize any (like AIM or any other messengers) you should uncheck these boxes if you are okay not having them boot when your computer does. This will make the boot of your computer much faster. When you are done click "Okay" and then choose "Exit without restart". The next time you reboot your computer these settings will be applied.
2. Uninstall unnecessary programs.
Click on the "Start" button and then open the control panel. Open the "Add or Remove Programs" tool. Locate each of the programs you do not use, and choose uninstall. Some things you can uninstall are toolbars and games. If you no longer use them, and you still have the CD for the game then remove the program before you keep it. Keep in mind that you can remove programs while still keeping your personal files for most games, this is a good move if you want to reinstall the game eventually.
3. Download and install Windows Updates.
Click on the "Start" button and find the "Windows Update" option under programs. Choose express install and download and install all of the updates recommended for your computer. You will likely have to restart your computer at the end of this process. When your computer has restarted, repeat this update process. Repeat until there are no longer any updates recommended for your computer (this may take three or even four update cycles).
4. Increasing your Hard Drive's efficiency.
Open up "My Computer" and then right-click on "Local Disk C:" and choose "Properties". Choose the "Tools" tab. You are going to run both the Defragmenter as well as Check disk utilities from this same spot.
  • Check Disk
    Click on the "Check Now..." button to initiate the check disk. Check both of the boxes here and run the check disk with these options, you will need to restart in order to finish this operation.
  • Defragment
    Go back into the Local Disk tools and click on the button "Defragment Now..." First choose the analyze button to determine if you need to defragment your drive or not, if it is recommended run a defragment. This whole process of optimizing your hard drive may take quite a while (just let each process run overnight).
5. Adding additional RAM (if necessary).
If your computer is still running slowly you need to add additional RAM to your computer. You need to find out what kind of RAM your computer requires (DDR, DDR2, DDR3...) and you can easily install it yourself. You should always buy RAM online as it is far less expensive online than it is in stores like Best Buy.
Maintenance
In order to keep the speed of your computer up, you need to regularly run full-computer antivirus scans with frequently updated software. Viruses, malware, and general junkware have a habit of slowing down your computer. Try installing free antivirus software following this tip:
http://www.fixya.com/support/r5317428-actually_free_antivirus_software_windows
Also be sure to regularly run the disk defragmenter (every six months), check disk (once a year) and install windows updates (once a month).
Your computer will now run much faster and will increase its life span significantly.
Please rate my tip!
Computers & Internet Logo
Do you have a Creative modem blaster driver for winxp?Model Number is DI5655
Yes we do!
Modem Drivers for Windows - Free downloads and reviews ...
download.cnet.com/windows/modem-drivers/ Results 1 - 10 of 4073 - The most downloaded Modem Drivers software, including GTConnect 3G Driver 3.313.zip, Samsung ... Windows XP AMD 64-bit (154).
PCI-Modem Drivers Download for Windows 10, 8.1, 7, Vista ...
www.driverscape.com/download/pci-modem Download the latest drivers for your PCI-Modem to keep your Computer up-to-date. ... OS: Windows 10, Windows 8.1, Windows 7, Windows Vista, Windows XP.
Fix PCI Modem Drivers Problems - Drivers.com
www.drivers.com/fix_pci_modem_drivers_problems.php Step-By-Step Instructions On How To Install PCI Modem Drivers at Drivers.com. ... Download PCI Modem Driver Update Tool, Windows 8, Windows 7, Vista, XP ...
Download Modem Drivers - Drivers.com
www.drivers.com/update_modem_driver_main.php Modem Drivers Download Tool at Drivers.com - latest Modem Drivers for your PC - Free Drivers ... Download Driver Update Tool, Windows 10, 8, 7, Vista, XP
Modem Drivers Download for Windows ' Free Driver ...
www.driverguide.com/driver/device/Modem-Drivers.html Popular Companies with Windows Modem Driver Downloads .... ladybird USB\VID_0572&PID_1321\24680246 (Windows XP Professional) [USB] 1 reply, Mar ...
Download Intel Modem driver for Windows 10, 8.1, 8, 7, XP
www.nodevice.com > Intel Download Intel Modem drivers for Windows 7, Windows 8, Windows 8.1, Windows 10, Windows XP. On this page you can download Intel 536EP Chipset Family, ...
Pci modem driver download - Drivers - Windows XP - Tom's Hardware
www.tomshardware.com > Forum > Windows XP Feb 12, 2013 - 2 posts - ‎1 author Hello, i want to download a pci modem driver for my computer. Modem drivers for windows 7 free download 3 posts 14 Jul 2012 Pci modem driver - Drivers - Windows XP 6 posts 29 Feb 2012 Problem Reinstalling PCI Modem, Windows XP [Solved ... 7 posts 28 Aug 2011 More results from www.tomshardware.com
Feb 06, 2016 | Computers & Internet
Cd in cdrom drive isn't recognized
1. click Start -> Run (for XP) or Start Search (Vista) or search for programs and files (Windows 7)
2. Type Regedit
3. Click on the plus sign beside HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
4. Under Class Click on the Folder {4D36E965-E325- ....} (note that the alpha numeric numbers are quite similar we only need ....65)
5. Look for UpperFilters and Delete it
6. Look for LowerFilters and Delete It
7. Restart the computer
May 25, 2011 | Computers & Internet
i want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
how to reformat my neo empriva 540nvb notebook. because the system is running slowly.
I will guide you the procedure.Which operating system you want to install Windows XP Or vista?
I will guide you the general procedure.
1) Take the back up of the any data in C drive.
2)Take your OS Re-installation cd/dvd insert it and boot from it.
3)After booting from re-installation disc, Follow the instructions to install the OS.
Note: If you are downgrading to Windows Xp, You need to follow different procedure.
The procedure is given in my other tip, below is the link to it.
http://www.fixya.com/support/r4636274-couldnt_find_harddisk_while_downgrade
Rate my solution.
Regards
May 24, 2010 | Computers & Internet
demo problem
If you have installed vista as a multiboot sytem, then you can do the below: Otherwise you have to do as tom19511 said:
Uninstall Windows Vista on a multiboot system
Applies to all editions of Windows Vista.
You cannot uninstall Windows Vista. However, you can change the code that starts the operating system (often called the master boot code), and then remove Windows Vista from your multiboot system and return to Windows XP or Windows 2000. You will need your Windows Vista installation disc for this procedure.
Before you begin, back up your programs, files, and settings. Removing Windows Vista is an advanced procedure that could result in losing information stored on your computer. For information about backing up data, search Help and Support for "back up."
1) Insert the Windows Vista installation disc.
2) Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3) Type [DVD drive letter]:\boot\bootsect.exe /nt52 ALL /force and then press ENTER.
For example, if the DVD drive letter is F, type f:\boot\ bootsect.exe /nt52 ALL /force.
4) Eject the Windows Vista installation disc.
5) Restart your computer.
Your computer will start in the previous version of Windows that you have installed.
6) Delete Windows Vista files and folders, such as the Program Files, Users, and Windows folders, manually.
Note: You can also remove Windows Vista by reformatting the partition where it is installed, but do this only if that partition is not the boot partition. Reformatting the boot partition might make your computer unable to start.
Nov 14, 2007 | Microsoft Windows Vista Ultimate Edition
437 people viewed this tip
David Payne
David Payne
