Tip & How-To about Plumbing
Squeaky Garage Door?
Use Lemon Pledge along the rails of your garage door to eliminate squeaks. Works as well or better than WD-40!
Plumbing Logo
HOW DO YOU FIX A SQUEAKING FRONT ENTRANCE DOOR TO YOUR HOUSE
Use a screwdriver, and perhaps a small hammer to pry the hinge pins out one at a time. After you get it out, use some WD-40 or silicone spray to wipe the dirt buildup off of it, then put a thin coat on and re-insert the pin.
If the door does not have hinge pins, use the WD-40 or silicone spray on the hinge and work the door back and forth until the squeaking stops.
Thanks for using Fixya.
May 07, 2011 | Computers & Internet
Xbox 360 Steering wheel - Pedals squeak - what sort of lubricant to use please?
I've been using wd-40. This is my second time using it in about 1 to 2 years. I just need to figure how to eliminate squeaks in the wheel. Good luck!
Oct 18, 2010 | Microsoft Wireless Racing Wheel for Xbox...
my garage door wont open more than 6 inches with the door attached to the belt, but when I releasae the door load the belt works just fine. It worked fine for 6 months but now i have this problem....
YOU MAY HAVE A BROKEN SPRING
CHECK TO SEE HOW THE DOOR WORKS MANUALLY - DISCONNECTED FROM THE OPENER. IF YOU CAN'T LIFT IT EASILY THE SPRING MAY NEED TO BE ADJUSTED OR REPLACED.
IF IT LIFTS EASILY BY HAND THEN LUBE (WHITE LITHIUM OR WD-40) THE SPRINGS, HINGES AND OPENER RAIL - TRY IT AGAIN, IF IT STILL REVERSES ADJUST THE OPEN SENSITIVITY 1/8 TURN AT A TIME IF IT TAKES MORE THAN 3/4 OF THE ADJUSTMENT RANGE OR STILL DOESN'T WORK I WOULD HAVE IT LOOKED AT BY A PRO. SOME THINGS YOU CAN LOOK RIGHT AT AND NOT SEE.
HOPE THIS IS HELPFUL
Sep 29, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
631 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
