Tip & How-To about Video Game Consoles & Games
How to get rid of red ring of death xbox 360
  • turn on xbox 360
  • cover it in towels
  • lots of them
  • make it nice and warm
  • make sure it is still flashing red
  • make sure it is all covered
  • leave it 30-45 minutes
  • it will work
  • if it dont work try again but with more towels
hope i helped
Video Game Consoles & Games Logo
Help.. My xbox has 3 reds lights
Hello.
This is a common problem from the Xbox 360.
The only way to fix this problem is to call Microsoft or email them. Its something to do with the hardware failure. Its over heated. Their is one way to fix it but temporary.
Its called the towel trick.
First, Unplug your xbox.
Then wrap it around with Heavy towels dont expose anything on the xbox 360. Cover everything.
Then plug in the xbox 360 while the towels are around it. After you do all that you wait 15 minutes. Then unwrap the towel from the xbox 360. It should be very hot. Let it cool down for 2 minutes then plug everything in and it should work.
But I hope this helps you.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 Red ring of death
If it still under warranty, contact Microsoft for a replacement.
There is no permanent fix for the Red Ring of Death.
Sep 01, 2008 | Video Game Consoles & Games
xbox 360
if you mean the 3 red lights, simple. You will need to have the xbox 360 running, 2 or so towels, and some time. First keep the xbox 360 running, then put the towels over the 360 (make sure to cover the vents). Keep it on for around 20 mins. Then after take off the towels, and let the system cool for another 20 mins. This should let it run for atleast another 2 hours.
Jun 15, 2008 | Microsoft Xbox 360 Console
xbox shuts down during a game 3 red lights
hey johnny you will have to call microsoft and get it fixed there is one thing you can do in the mean time to temp fix it.
what you need is two towels just normal bathroom towels take everything out of your xbox e.g harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about 20 mins then after that take all the towels off turn off the console and leave to cool down for 15 mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you have to do it again. wont fix it but will let u play while microsoft gets it.
hope this helps please rate me
regards grant
Nov 23, 2007 | Microsoft Xbox 360 Console
HELP
will be a hardware error
will have to contact microsoft there is a temperory fix for this problem. what you need is two towels just normal bathroom towels take everything out of your xbox e.g
regards Grant
Nov 22, 2007 | Microsoft Xbox 360 Console
622 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
