Tip & How-To about Heating & Cooling
Dehumidifier making too much water
Sorry folks, those who complain that their dehumidifier is making too much water seem to fail to understand, that is what it is supposed to do. If it is a portable unit, yes, it is a pain in the neck to have to keep emptying it. Check your owner's manual to see if it can be modified to be piped to a permenant drain. Next time, purchase a bigger model.
Heating & Cooling Logo
frigidaire dehumidifier
Good Afternoon Friend,
I understand that there is no water coming out of your Frigidaire dehumidifier, model# FDF50S1. I also see that the filter is fine and the fan is running. If you have your dehumidifier set up to continuously drain through a garden hose, make sure there are no kinks or clogs in the garden hose. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire Dehumidifiers
how do I connect my dehumidifier with a hose directly to a drain
Are you much of a handyman? Most folks set their dehumidifier on a counter or elevated and run the exhaust tubing right into a sink or toilet. You could collect the water to flush a toilet or water the grass if you are handy. I've never seen anyone connect directly to a drain though.
Jun 04, 2014 | Comfort-Aire BHD-501 Dehumidifier
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
dehumidifier
if it does not get cold anymore, then a freon charge is necessary, provided the compressor was not damaged from "left it on for a long time once and found that ice had developed on it. I know that being left on could cause a problem"
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
225 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
