Tip & How-To about Heating & Cooling
Window air conditioner blows warm
There are a number of things that cause a window air conditioner to blow warm air. None of them good. A faulty thermostat. A small leak which requires repair and recharge of refrigerant. A bad compressor. A bad capacitor. The list goes on.
As an air conditioning mechanic, I earn a good wage. Add cost of a vehicle, auto insurance, gasoline, cost of inventory, the person that answers the phone at the office, liability insurance, unemployment insurance, workman's compensation insurance, payroll taxes, taxes on inventory, my accountant's fees, my attorney's fees the donations to the local little league teams, cost to purchase and maintain my large number of highly specialized tools and instruments .... My hourly rate, depending on what part of the country I'm in, is at least $75.00. Add $25 to $75 for the most basic of parts. Your repair is going to run at least $100.00.
Unless your window airconditioner is a very large, commercial unit, it will be much less expensive and quicker for you to go to Walmart, Kmart, Target or the Big Box store of your choice and get another one.
Heating & Cooling Logo
Blowin warm air, filter cleaned
The compressor may not be coming on,see if it is humming,and if it is,the compressor maybe bad,or out of freon.If it is not running(compressor)then the thermostat maybe bad.
Nov 13, 2009 | Samsung AW1893L Air Conditioner
Why is my 1998 for Exxplorer blowing cool and warm air when air conditioner is on?
THE AC MAY HAVE A LEAK AND IS LOW ON CHARGE, THE COMMON REASON FOR THIS IS A LEAKING CONDENSOR CORE AND THE AC LINE "O" RINGS LEAKING.
Jul 23, 2009 | 1998 Ford Explorer
AIR DOES NOT WORK DO I JUST NEED FREEON
If the air conditioner blow warm air,
1. Open the hood and check the fan belt first, sometime the fan belt broke caused the compressor stop to work, if the fan belt is good, check the compressor see if the center part turns, if turns, that means the compressor is o.k.
2. If both work fine, check the air conditioner small window see if there is bubble, if you see some bubbles in the small round window, that’s means your air conditioner lack
R-22 Freon.
3. before you fill up the Freon, check the leaking, if leaks, fix it and then fill up the Freon, the best way is to ask some professional auto air conditioner repair shop to help you.
Hope this can help you.
Jun 12, 2008 | 1996 Chrysler Cirrus
my air conditioner keeps blowing warm
Help us by giving us more info. Is it a window air conditioner? Make and Model number? Have yu checked the air filter?
Aug 27, 2007 | Honeywell Programmable Thermostat Heater
371 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
